20
I can't find the way to add a custom menu entry to a .desktop launcher.
In Unity I was able to add custom menu entries to launcher like "Open customfile.txt" or "Open somespreadsheet.ods". Is that possible in Ubuntu Dock?
razor7
  • 1,589
Follow the steps below.
  1. Copy .desktop file associated to your preferred application, say app-name.desktop from /usr/share/applications/ to ~/.local/share/applications/. You can do this by running the following command in Terminal
    cp /usr/share/applications/app-name.desktop ~/.local/share/applications/
  2. Open the .desktop file using a text-editor, for example by running
    gedit ~/.local/share/applications/app-name.desktop
  3. Look for a line beginning with Actions=. If there is one, append My-Custom-Action; to it. Otherwise, add the following line
    Actions=My-Custom-Action;
  4. Write the following lines at end of the file:
    [Desktop Action My-Custom-Action]
    Name=Name of the Option
    Exec=command-you-want-to-run
    For example, if you want to open Text editor, put gedit in place of command-you-want-ro-run.
  5. Save the file.
  6. Click on "Activities" and search for the application.
  7. Right-click on the application icon and select "Add to Favourites". It should be added to the Ubuntu dock.
Now if you right-click on the newly added application icon in the dock, you should see a "Name of the Option" entry in the context menu which should work as expected.
Similarly, you can other options by adding new Desktop Actions and adding the name of the action to the Actions= line. For more info see this.
pomsky
  • 70,557
