I've got the Dell XPS 13 Developer Edition laptop, of which I am a big fan. My touchpad works in 17.10 without a problem, but when I boot into 18.04, I get bad behaviour. I can move the pointer, but it's jerky, and just stops following my touchpad movement.
It works fine when I boot to a 17.10 USB key. Using a USB mouse also works fine. The problem occurs when I have a USB mouse connected or not.
I get the same behaviour when I start an Xorg session or a Wayland session, so my guess is that the problem is at a lower level, like the kernel.
I had the same problem (xps13, update to 18.04) and did the same as in Synaptic touchpad on laptop not working:
sudo modprobe -r psmouse
sudo modprobe psmouse proto=imps
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Hugo
  • 41
This fixed my Dell XPS (Cyprus touchpad) issue on Mate Ubuntu 18.04. I saw the issue in both Mate and regular Ubuntu.
sudo apt-get install xserver-xorg-core
sudo apt-get install xserver-xorg-input-synaptics
sudo apt-get install xserver-xorg-input-all
Then reboot
I installed xf86-input-synaptics and I made some changes to /etc/X11/xorg.conf.d/70-synaptics.conf.
sudo cp /usr/share/X11/xorg.conf.d/70-synaptics.conf /etc/X11/xorg.conf.d/
You can check what settings Synaptics with:
synclient -l
and you can try some settings like:
synclient TapButton1=1
I think this is not perfect, but now I can sleep well.
Ref:
David Foerster
  • 36,890
  • 56
  • 97
  • 151
