I thought I already had the time up there in the top bar, and it may have been so in previous Ubuntu versions (don't remember, my Ubuntu laptop is just one of three computers I use). Only that I just noticed - me being someone who never wears a watch, has the cellphone turned off 95% of the time and relying on the computer to tell the time - that there is no time being displayed anywhere, and I had expected it in the top bar on the Unity desktop.
I searched around but found no obvious solution, but I'm sure someone immediately knows how I can get my time (back?) into the top bar?
jokerdino
  • 41,732
Mörre
  • 123
The time is shown by default, so it looks like you've changed something to make it disappear.
Do you still see the date? Right-click the date, select "Time & Date Settings", go to the "Clock" tabsheet, make sure that "Show a clock in the menu bar" is checked.
If you don't see the date, go to System Settings, where you'll also find the "Time & Date" settings.
There is no longer a "Time & Date" setting in System Setting - Ubuntu 12.10 - but this link describes how to enable these on the display:
(note: dconf-editor is already installed by default)
How to make the date appear next to the time indicator in Gnome Classic?
Jesper
  • 2,247
If after installing the app and correcting config, the date&time are "greyed-out", then it means your chosen region is not matched to your local server.
To correct:
1/ set the time&date to your actual region (eg China)
2/ use synaptic to select the repository server for your actual region (eg China).
3/ reboot.
This should solve the issue. Recurrence may be caused by change in location, or change in server, or update/upgrade. If so, repeat the above.
rob grune
  • 1,161
-1
Open the terminal and run the command killall unity-panel-service
muru
  • 207,228
achini
  • 101
