I upgraded to ubuntu 18.04 from ubuntu 16.04. But after restarting the login screen was same as 16.04 and still 16.04 lts was written at the bottom. And when I try to login I can't as it shows a black screen momentarily but again redirects to login page. Tell me what to do?
Asked
Active
Viewed 1,120 times
Ubuntu 16.04 uses lightdm as login manager. This is (obviously) preserved if you upgrade to 18.04. If you prefer to use gdm, you will need to switch from lightdm to gdm. How you can do that is explained elsewhere on Askubuntu. How do I switch from LightDM to GDM?
vanadium
- 97,564
You can reinstall lightdm (by removing and installing again) and when it asks what manager to use, don't select lightdm and instead, you need to select gdm3 and then uninstall lightdm.
grooveplex
- 2,506
- 3
- 27
- 35
viriv
- 1
