My WiFi was working perfectly in Ubuntu 16.04.4. I rebooted my laptop and after logging in, nm-applet did not show any WiFi AP. WiFi modem is up and running. But My nm-applet did not show anything.
- I have tried downgrading my kernel and reinstalling the Broadcom drivers but it did not work.
- I have tried to insall the older version of the broadcom driver but it also gave me the same error
modprobe: ERROR: could not insert 'wl': Exec format error - My WiFi works when I use it from live pendrive.
- I have tried the steps in these
But even then my WiFi is not working.
$ iwconfig gives
lo no wireless extensions.
enp3s0 no wireless extensions.
My Kernel version: 4.4.0-116-generic
$ls /lib/modules/4.4.0-116-generic/updates/dkms/ gives
wl.ko
$ lspci -vvnn | grep -A 9 Network gives
02:00.0 Network controller [0280]: Broadcom Limited BCM43142 802.11b/g/n [14e4:4365] (rev 01)
DeviceName: NAMI
Subsystem: Hewlett-Packard Company BCM43142 802.11b/g/n [103c:804a]
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 3
Region 0: Memory at f0c00000 (64-bit, non-prefetchable) [size=32K]
Capabilities: <access denied>
Kernel modules: bcma, wl
$ lshw -C network spits
*-network UNCLAIMED
description: Network controller
product: BCM43142 802.11b/g/n
vendor: Broadcom Limited
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:f0c00000-f0c07fff
*-network
description: Ethernet interface
product: RTL810xE PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 07
serial: fc:3f:db:d5:e7:d7
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8106e-1_0.0.1 06/29/12 ip=192.168.1.8 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:32 ioport:2000(size=256) memory:f0b00000-f0b00fff memory:f0800000-f0803fff
$ sudo apt --reinstall bcmwl-kernel-source
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libqscintilla2-12v5 libqscintilla2-l10n libqt4-opengl linux-headers-4.4.0-119
octave-info thermald
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
bcmwl-kernel-source
1 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
Need to get 0 B/1,544 kB of archives.
After this operation, 51.2 kB of additional disk space will be used.
(Reading database ... 374783 files and directories currently installed.)
Preparing to unpack .../bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu1~1.2_amd64.deb ...
Removing all DKMS Modules
Done.
Unpacking bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.2) over (6.30.223.248+bdcom-0ubuntu8) ...
Setting up bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu1~1.2) ...
Loading new bcmwl-6.30.223.271+bdcom DKMS files...
Building only for 4.4.0-116-generic
Building for architecture x86_64
Building initial module for 4.4.0-116-generic
Done.
wl:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/4.4.0-116-generic/updates/dkms/
depmod....
DKMS: install completed.
update-initramfs: deferring update (trigger activated)
Processing triggers for shim-signed (1.33.1~16.04.1+13-0ubuntu2) ...
Secure Boot not enabled on this system.
Processing triggers for initramfs-tools (0.122ubuntu8.11) ...
update-initramfs: Generating /boot/initrd.img-4.4.0-116-generic
