I am trying to use scripts such as sox and rec without the mic | Ask Ubuntu and recording from PulseAudio | outflux.net
If I ssh into the box and try to run any command such as
pactl list short sources
I get back
root@blue:~# pactl list short sources
No protocol specified
xcb_connection_has_error() returned true
Connection failure: Connection refused
pa_context_connect() failed: Connection refused
root@blue:~#
I get the same if I try parec. Now if I try it from the desktop it works fine. I am using Ubuntu 16.0.4. Any idea what would cause this? Doing the same on CentOS 7 has no such issue.
As far as I can tell, xcb_connection_has_error is part of:
walt@bat:~(0)$ man xcb_connection_has_error
No manual entry for xcb_connection_has_error
walt@bat:~(16)$ man -k xcb_connection_has_error
xcb_connection_has_error: nothing appropriate.
xcb_connection: nothing appropriate.
DES_xcbc_encrypt (3ssl) - DES encryption
XGetXCBConnection (3) - get the XCB connection for an Xlib Display
XSetEventQueueOwner (3) - set event queue owner on a shared Xlib/XCB connection
X Windows. What's your $DISPLAY variable set to on both systems? Have you tried the -v, -X and -x options to your ssh command?
Since strings $(type -p pactl) | grep DISPLAY returns 1 (no match), pactl does NOT directly make use of X Windows and cannot get X Windows errors(xcb_connection_has_error).
waltinator
  • 37,856
