I am a beginner for Ubuntu, for last few days I'm facing this upgrade problem whenever I try to upgrade to new updates, as soon as I click install updates it starts the process and then ultimately shows an error message "package operation failed", one among those is very common is the following:
I tried to check this issue here and found a post asking about similar problem Here
What suggested there is that I should run following code in terminal:
sudo rm /var/crash/*
I did and now I am not getting this pop up showing system program problem detected but it seems that "error code (1)" problem still exist. Today I was trying to install gcc and it shows the same error. So I request that kindly help me to resolve this issue. Thank you!
In my latest attempt of updating I got the following error messages,
admins@admins-desktop:~$ sudo apt-get install build-
essential
Reading package lists... Done
Building dependency tree
build-essential is already the newest version (12.1ubuntu2).
The following packages were automatically installed and are no longer
required:
 apt-xapian-index gimp-data gimp-help-common gimp-help-en gir1.2-
gmenu-3.0
libamd2.4.1 libbabl-0.1-0 libbonobo2-0 libbonobo2-common libcamd2.4.1
libccolamd2.9.1 libcholmod3.0.6 libgegl-0.3-0 libgimp2.0 libgnome-2-0
libgnome2-common libgnomevfs2-0 libgnomevfs2-common libgtkglext1
libgutenprintui2-1 libllvm3.8 libllvm4.0 libmircommon5 libopencc1
   liborbit-2-0 libpango1.0-0 libpangox-1.0-0 libpython-stdlib
libpyzy- 1.0-0v5
         libqmi-glib1 libqt4-designer libqt4-help libqt4-opengl
libqt4-
scripttools
libqt4-svg libqt4-test libqtassistantclient4 libqtwebkit4 librsync1
libsdl1.2debian libtiff-tools libumfpack5.7.1 libxapian-1.3-5
linux-headers-4.4.0-109 linux-headers-4.4.0-109-generic
linux-headers-4.4.0-112 linux-headers-4.4.0-112-generic
linux-headers-4.4.0-36 linux-headers-4.4.0-36-generic linux-headers-
4.4.0-66
  linux-headers-4.4.0-66-generic linux-headers-4.4.0-70
  linux-headers-4.4.0-70-generic linux-headers-4.4.0-83
  linux-headers-4.4.0-83-generic linux-headers-4.4.0-98
  linux-headers-4.4.0-98-generic linux-image-4.4.0-109-generic
  linux-image-4.4.0-112-generic linux-image-4.4.0-36-generic
  linux-image-4.4.0-66-generic linux-image-4.4.0-70-generic
  linux-image-4.4.0-83-generic linux-image-4.4.0-98-generic
linux-image-extra-4.4.0-109-generic linux-image-extra-4.4.0-112-
generic
linux-image-extra-4.4.0-36-generic linux-image-extra-4.4.0-66-generic
linux-image-extra-4.4.0-70-generic linux-image-extra-4.4.0-83-generic
linux-image-extra-4.4.0-98-generic linux-signed-image-4.4.0-109-
generic
linux-signed-image-4.4.0-112-generic linux-signed-image-4.4.0-36-
generic
linux-signed-image-4.4.0-66-generic linux-signed-image-4.4.0-70-
generic
linux-signed-image-4.4.0-83-generic linux-signed-image-4.4.0-98-
generic
oneconf-common python-cffi-backend python-cups python-httplib2 python-
lxml
python-pam python-serial python-twisted-bin python-xapian python3-
oneconf
python3-piston-mini-client python3-xapian1.3 snap-confine
ubuntu-core-launcher ubuntuone-client-data
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
10 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up initramfs-tools (0.122ubuntu8.11) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-4.4.0-119-generic (4.4.0-119.143) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-4.4.0-119-
generic
vmlinuz(/boot/vmlinuz-4.4.0-119-generic
) points to /boot/vmlinuz-4.4.0-119-generic
(/boot/vmlinuz-4.4.0-119-generic) -- doing nothing at
/var/lib/dpkg/info/linux-image-4.4.0-119-generic.postinst line 491.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-
119-generic /boot/vmlinuz-4.4.0-119-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-119-
update-initramfs: Generating /boot/initrd.img-4.4.0-119-generic
E: /usr/share/initramfs-tools/hooks/brltty failed with return 1.
update-initramfs: failed for /boot/initrd.img-4.4.0-119-generic with
1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return
code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-
image-4.4.0-119-generic.postinst line 1052.
dpkg: error processing package linux-image-4.4.0-119-generic (--
configure):
 subprocess installed post-installation script returned error exit
status 2
dpkg: dependency problems prevent configuration of linux-image-extra-
4.4.0-119-generic:
linux-image-extra-4.4.0-119-generic depends on linux-image-4.4.0-119-
generic; however:
 Package linux-image-4.4.0-119-generic is not configured yet.
dpkg: error processing package linux-image-extra-4.4.0-119-generic (--
configure):
dependency problems - leaving unconfigured
generic:
linux-image-generic depends on linux-image-4.4.0-119-generic; however:
linux-image-generic depends on linux-image-extra-4.4.0-119-generic;
however:
Package linux-image-extra-4.4.0-119-generic is not configured yet.
dpkg: error processing package linux-image-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 4.4.0.119.125);
 however:
 Package linux-image-generic is not No apport report written because
 the error message indicates its a followup error from a previous
 failure.
                                                           No apport
report written because the error message indicates its a followup
error from a previous failure.
     No apport report written because MaxReports is reached already
        No
                                                   No apport report
already
                                                         configured
yet.
dpkg: error processing package linux-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic-lts-
utopic:
linux-generic-lts-utopic depends on linux-generic; however:
Package linux-generic is not configured yet.
dpkg: error processing package linux-generic-lts-utopic (--configure):
dpkg: dependency problems prevent configuration of linux-signed-image-
4.4.0-119-generic:
linux-signed-image-4.4.0-119-generic depends on linux-image-4.4.0-119-
generic (= 4.4.0-119.143); however:
dpkg: error processing package linux-signed-image-4.4.0-119-generic (-
-configure):
generic:
linux-signed-image-generic depends on linux-signed-image-4.4.0-119-
generic; however:
Package linux-signed-image-4.4.0-119-generic is not configured yet.
linux-signed-image-generic depends on linux-image-extra-4.4.0-119-
generic; however:
dpkg: error processing package linux-signed-image-generic (--
configure):
generic:
linux-signed-generic depends on linux-signed-image-generic (=
4.4.0.119.125); however:
Package linux-signed-image-generic is not configured yet.
dpkg: error processing package linux-signed-generic (--configure):
generic-lts-utopic:
linux-signed-generic-lts-utopic depends on linux-signed-generic;
however:
Package linux-signed-generic is not configured yet.
dpkg: error processing package linux-signed-generic-lts-utopic (--
configure):
Processing triggers for initramfs-tools (0.122ubuntu8.11) ...
update-initramfs: Generating /boot/initrd.img-4.4.0-116-generic
update-initramfs: failed for /boot/initrd.img-4.4.0-116-generic with
1.
dpkg: error processing package initramfs-tools (--configure):
status 1
                                                          Errors were
encountered while processing:
 linux-image-generic
 linux-generic
 initramfs-tools
I also want to know how to post long code section as I did because when I tried to copy paste it was not taking it as a code segments rather it took it as in text format. I tried many times but all in vain then I shifted whole code by the suggested margin to make it as code attachment. Even though I was eventually capable of doing it but it was really frustrating and tedious to shift every single line so I also want to know how to paste long code here as a code segment by copying through terminal window. Thank you and I apologize for such a long post. Thanks again!
weatherman
  • 305
