I can make VLC use hardware decoding with
vlc --ffmpeg-hw video.mkv
Is there an equivalent flag for mplayer?
sashoalm
  • 5,241
Mind you if you have an nVidia graphics card you should not only specify the -vo device but also give a -vc setting. On my own system I give the following on the commandline:
mplayer -vo vdpau filename
(replacing 'filename' with the actual name of your file of course) and place the following in ~/.mplayer/config:
[vo.vdpau]
vc=ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau,ffh264vdpau,ffodivxvdpau,
but there are several different ways of doing this. This method allows you to use different video out devices with MPlayer but will give proper -vc values when you specify -vo vdpau from the commandline.
Hope this helps :).
andrew.46
  • 39,359
The command is -vo (video out). For my nVidia network card with hardware acceleration, I use -vo vdpau.
To see all of the video out processors, see mplayer.1.
