I was trying to install git-lfs on UBuntu 14.04 . There was some error , some steps which i did at random and dont remember the exact sequence of steps but am stuck at this .
Wherever i try to install any package , i get the below error -
root@saurabh-Lenovo-Z50-70:~# apt-get install iperf
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  iperf
0 upgraded, 1 newly installed, 0 to remove and 148 not upgraded.
1 not fully installed or removed.
Need to get 0 B/54.4 kB of archives.
After this operation, 169 kB of additional disk space will be used.
(Reading database ... 139 files and directories currently installed.)
Preparing to unpack .../iperf_2.0.5-3_i386.deb ...
Unpacking iperf (2.0.5-3) over (2.0.5-3) ...
dpkg: error processing package git-lfs (--configure):
 package git-lfs is already installed and configured
No apport report written because the error message indicates its a followup error from a previous failure.
        dpkg: dependency problems prevent configuration of iperf:
 iperf depends on libc6 (>= 2.15); however:
  Package libc6 is not installed.
 iperf depends on libgcc1 (>= 1:4.1.1); however:
  Package libgcc1 is not installed.
 iperf depends on libstdc++6 (>= 4.1.1); however:
  Package libstdc++6 is not installed.
dpkg: error processing package iperf (--configure):
 dependency problems - leaving unconfigured
 git-lfs
 iperf
I tried removing git-lfs by doing apt-get purge git-lfs , apt-get autoclean but nothing seems to help .
Please let me know how can the dpkg be fixed . I dont need git-lfs anymore , so i am ok to remove it completely .
Tried out the suggestions in Package system is broken. How to fix it? .
root@saurabh-Lenovo-Z50-70:~# apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 144 not upgraded.
After this operation, 0 B of additional disk space will be used.
 git-lfs
apt-get clean and apt-get update work but then the apt-get install -f fails. And i didnt have synaptic installed before this , so now not able to install any new package .
