I am trying to setup multitouch gestures on ubuntu 17.10, but for some reason, I can't install libinput-tools.
Error:
 libinput-tools : Depends: libinput10 (= 1.8.4-0ubuntu0.17.10.1) but 1.8.2-1ubuntu2 is to be installed
I know libnput10 is installed by default because ubuntu 17.10 replaced synaptics, so libinput-tools should work too?
J. Doe
It looks like you are working on outdated repository packages for some reason (I've installed it locally, all the correct versioned dependencies are available).
There are a number of reasons* why this may be the case, but try the following:
sudo apt-get update
sudo apt-get -f install
* Reasons for outdated repository packages/info:
  1. You haven't pulled the latest package list (see sudo apt-get update to do this)
  2. The repository mirror is out of date - ie it should have sync'd from the main ubuntu repositories, but for whatever reason, that sync didn't happen/happened halfway through an update/failed to complete for some reason.
    This issue is out of your control (you can't fix the repository), but you can change which mirror your install points to - check out this thread:
    How do I change mirrors in Ubuntu Server from regional to main?
    Then retry the two original steps above -
cleary
  • 684
