I need to update a 17.04 VM of lubuntu running in Oracle VirtualBox to 17.10. When I try the update, there was not enough free space despite removing any data files (the VM disk was only 10G, so not much space to reclaim).
I successfully grew the VirtualBox .vdi file to many more gigs, but following the steps here, I need to run gparted, which sadly is not on my 17.04 machine! It's a catch-22, because I can not install it since the (17.04) mirrors are no longer available anymore because it's EOL. Am I SOL?
I checked out - https://unix.stackexchange.com/questions/179577/how-do-i-resize-a-windows-partition-without-using-gparted but it seems to apply to Windows (and is really complex).
Is there a solution which doesn't require a fresh install? I'd like to keep my config of the 17.04 if possible.
Edit: As I already pointed out, I know 17.04 is EOL. How to install software or upgrade from an old unsupported release? is related but not a duplicate. I need to modify the partition of a drive to do an update, but can't get the software.
