54
I would like to understand what a masked service is and how to unmask it if need be.
I have been trying to start PostgreSQL on Ubuntu 16.04-LTS using the command
systemctl start postgresql.service.
Both as a user with administrative privileges, as well as root respectively.
Unfortunately, I got
Failed to start postgresql.service: Unit postgresql.service is masked.
printed in both scenarios.
Zanna
  • 72,312
Joseph-L-S
  • 1,113
Masking a service will prevent it from starting.
To unmask a service run:
systemctl unmask name.service
Source:
How to Manage Systemd Services on a Linux System | How To Geek
Jeff
  • 1,724
I had an issue with mysql/mariadb services stopping suddenly then becoming masked. Running
journalctl -xe
Will generally show you ~why~ a service gets disabled/masked/won't start/etc. Generally it's for a very good reason.
In my case it was installing a new repository (for an unrelated service) that just happened to have a downgraded version of mariadb-server.
When I ran the apt upgrade, mariadb got downgraded and the service "masked"
In my case upgrading mariadb to the correct version fixed the issue and unmasked the service itself, just unmasking the service could have caused data corruption in the mysql dbs.... so basically, don't just blindly unmask something - figure out why.
I have found that this error message results from errors in the service creation process. Such as not naming the file .service but instead .sevrice.
I was attempting to create a service and when setting it up I sometimes transposed letters in the file extension. As a result systemd on ubuntu 21.10 reported that my service was masked and when I unmasked the service ubuntu deleted the service file like it was a thief that had been unmasked :^). Confused me for a few minutes until I saw the tranposed letters.
kkron
  • 151
In my case, this works for me:
sudo apt install php8.1-fpm
sudo systemctl enable php8.1-fpm
sudo systemctl start php8.1-fpm
