First check if anaconda3 is installed on your system or not (Sometime the package may be broken due to network issues during installation). And whether you are able to launch anaconda-navigator without a desktop entry or not (See how to launch anaconda-navigator without a desktop-entry, later in this post).
For creating a desktop entry
Step 1. Open your text editor and save the following content as Anaconda.desktop to your home directory.
[Desktop Entry]
Version=1.0
Type=Application
Name=Anaconda-Navigator
GenericName=Anaconda
Comment=Scientific Python Development Environment - Python3
Exec=bash -c 'export PATH="/home/jishan/anaconda3/bin:$PATH" && /home/jishan/anaconda3/bin/anaconda-navigator'
Categories=Development;Science;IDE;Qt;Education;
Icon=/home/jishan/anaconda3/lib/python3.6/site-packages/anaconda_navigator/static/images/anaconda-icon-256x256.png
Terminal=false
StartupNotify=true
MimeType=text/x-python;
Change the user-name to your username in Icon=/home/jishan/anaconda3/lib/python3.6/site-packages/anaconda_navigator/static/images/anaconda-icon-256x256.png i.e. replace jishan by your username.
Step 2. Copy your Anaconda.desktop to /usr/share/applications/ as root (Because you might need permission to copy at /usr/share/applications/)
sudo cp Anaconda.desktop /usr/share/applications
This will create a desktop entry named Anaconda in /usr/share/applications/.
Step 3. Check if Anaconda is added to your application dock. If you didn't find it, search it in search-bar. Or you can run directly from /usr/share/applications/Anaconda.desktop.
Launch Anaconda-navigator without a desktop entry
Your user (not root) may not have access to anaconda-navigator or it is not activated it yet.
Source ~/anaconda3/bin/activate root
This will result in single line showing (bash), if installed. If it is not installed, install it from here.
If installed, you can launch now by
anaconda-navigator
This will result in opening anaconda-navigator. (For each time you've to activate root as soon as your session is destroyed).
