As explain in this thread, I want to add shortcuts to switch workspaces (in Mate).
I found a way to switch workspace for the terminal: wmctrl -s $(wmctrl -d | grep "*" | awk '{print $1+1}').
But this command line does not work when I add it in the shortcut manager. Does any one know why ?
Phantom
  • 163
IIRC keyboard shortcut commands are running in an sh shell, which doesn't have all the features Bash has.
Your command uses some bash-specific syntax though, which is why it doesn't work. The simplest fix is to simply run it in a Bash shell by replacing it with this command below:
bash -c "wmctrl -s $(wmctrl -d | grep '*' | awk '{print $1+1}')"
Byte Commander
  • 110,243
