It's not possible to pass multiple parameters to the a systemd template (see related mailing list discussion). However, since we have only two parameters and one is the username, it makes sense to make it a user service instead of a system service.
User services can be run at boot if you enable lingering for those users:
sudo loginctl enable-linger username
From man loginctl:
enable-linger [USER...], disable-linger [USER...]
Enable/disable user lingering for one or more users. If enabled for
a specific user, a user manager is spawned for the user at boot and
kept around after logouts. This allows users who are not logged in
to run long-running services. Takes one or more user names or
numeric UIDs as argument. If no argument is specified,
enables/disables lingering for the user of the session of the
caller.
You can create a user service at /etc/systemd/user, which would look like (adapting your earlier service):
[Unit]
Description=Start TigerVNC Server at startup
After=syslog.target network.target
[Service]
Type=forking
PAMName=login
PIDFile=%h/.vnc/%H:%i.pid
ExecStartPre=-/usr/bin/vncserver -kill :%i > /dev/null 2>&1
ExecStart=/usr/bin/vncserver :%i -depth 24 -geometry 1920x1080 -nolisten tcp -localhost
ExecStop=/usr/bin/vncserver -kill :%i
[Install]
WantedBy=default.target
Use the %h specifier for the user home directory. I have omitted the User= field, which doesn't make sense in user sessions. Also note the change to WantedBy in [Install] from multi-user.target (which does not exist in user sessions) to default.target.
The users can then control this service using systemctl --user commands. (Note that you might need to restart after enabling linger if that user hasn't logged in yet, so that a user session is started for them.)
