I have just updated my Ubuntu and set my printer back to factory settings, after which I reinstalled my printer (same way as before) but this time I'm getting a "Device Communication error (5012)".
I googled and found this solution and several referrals to it. The issue they mention seems to be exactly mine, only the way the solution is solved gives me questions.
Neither in hp-toolbox nor hp-setup do I find a field in which I can modify the
hp:/usb/HP_Color_LaserJet_MFP_M477fdw?serial=XXXXXXXXX
or
hpfax:/usb/HP_Color_LaserJet_MFP_M477fdw?serial=XXXXXXXXX
and change the serial=XXXXXXXX to ip=192.168.0.xxx.
Does anyone have any ideas about this? Maybe I can manually edit a file? Or, in the hp-setup I did see the fields network identification/hostname, but I didn't want to mess with this as I'm not sure, as it also wouldn't change the serial= to ip=, just the name to the number.
I just realised that when i plug in my usb cable the fax and printer under hp toolbox seem to be oke. the issue under hp-check still remains though but no Device Communication error (5012).
so to me it seems like the printer is not installed as wifi but as usb, maybe it is just that that is being fixed by changing the "serial=XXXXXXXX" to "ip=192.168.0.xxx",i'm really not sure.
summary of output:
# hp-check -i
Saving output in log file: /home/matt/hp-check.log
HP Linux Imaging and Printing System (ver. 3.17.10)
Dependency/Version Check Utility ver. 15.1
| INSTALLED CUPS PRINTER QUEUES |
HP-Color-LaserJet-MFP-M477fdw
Type: Printer
Device URI: hp:/usb/HP_Color_LaserJet_MFP_M477fdw?serial=VNBKKDH3WN
PPD: /etc/cups/ppd/HP-Color-LaserJet-MFP-M477fdw.ppd
**warning: Failed to read /etc/cups/ppd/HP-Color-LaserJet-MFP-M477fdw.ppd ppd file**
PPD Description:
Printer status: printer HP-Color-LaserJet-MFP-M477fdw is idle.
enabled since Tue 06 Mar 2018 23:07:59 CET
Required plug-in status: Installed
**error: Unable to communicate with device (code=12):
hp:/usb/HP_Color_LaserJet_MFP_M477fdw?serial=VNBKKDH3WN**
**error: Device not found**
**error: Communication status: Failed**
HP-Color-LaserJet-MFP-M477fdw-Fax-2
Type: Fax
Device URI: hpfax:/usb/HP_Color_LaserJet_MFP_M477fdw?serial=VNBKKDH3WN
PPD: /etc/cups/ppd/HP-Color-LaserJet-MFP-M477fdw-Fax-2.ppd
**warning: Failed to read /etc/cups/ppd/HP-Color-LaserJet-MFP-M477fdw-
Fax-2.ppd ppd file**
PPD Description:
Printer status: printer HP-Color-LaserJet-MFP-M477fdw-Fax-2 is idle.
enabled since Tue 06 Mar 2018 23:08:05 CET
hpfax:/usb/HP_Color_LaserJet_MFP_M477fdw?serial=VNBKKDH3WN**
| PERMISSION |
| SUMMARY |
Missing Required Dependencies
error: 'libcups2' package is missing/incompatible
error: 'libdbus-1-dev' package is missing/incompatible
error: 'libjpeg-dev' package is missing/incompatible
error: 'libcups2-dev' package is missing/incompatible
error: 'cups-bsd' package is missing/incompatible
error: 'cups-client' package is missing/incompatible
error: 'libcupsimage2-dev' package is missing/incompatible
error: 'libsane-dev' package is missing/incompatible
error: 'libsnmp-dev' package is missing/incompatible
error: 'snmp-mibs-downloader' package is missing/incompatible
error: 'openssl' package is missing/incompatible
error: 'python3-pyqt4' package is missing/incompatible
error: 'gtk2-engines-pixbuf' package is missing/incompatible
Missing Optional Dependencies
error: 'python3-dbus.mainloop.qt' package is missing/incompatible
Total Errors: 12
Total Warnings: 0
sorry i couldn't get the bold in the code to work?
Pang
  • 373
9 Answers9
For Ubuntu 22.04:
sudo apt remove ipp-usb
Ján Nosko
  • 51
This is what I did to solve it.
  1. Installed fresh install from Ubuntu 17.10:
    sudo do-release-upgrade -d
  2. Removed all references (so far I knew to find them) from /etc/cups basically sudo-ed and cleaned the entire folder out.
  3. auto-removed hplip-gui
    sudo apt remove --auto-remove hplip-gui
  4. Somewhere here I was asked to partially update Ubuntu, which afterwards showed that it became a development version of 18.04. Unfortunately I'm not sure if that was induced or just happened, and also don't know it that matters or how to find out.
  5. auto-removed hplip
  6. Downloaded hplip-3.17.11 from the HP website.
  7. Installed hplip-3.17.11 following the installation notes from HP website.
  8. Paid special attention to the installation notes at the beginning of the installation and followed them as such.
    8a. Software & Updates: Made sure it was on main-server.
    8b. Locked the CD-ROM by:
    eject -i 1
  9. Installed hplip-3.17.11
    cd Desktop
    sudo sh hplip-3.17.11.run
    There were no dependency problems at all!
  10. Installed printer during install via GUI.
The printer seems to be properly set -up, no communication error 5012,
via wifi, just still not found by xsane.
Update: I get an unsupported platform warning when running hp-doctor and an HPLIP error: Unable to communicate with device (code=12)
karel
  • 122,292
  • 133
  • 301
  • 332
For the record: The problem is present in 18.04 with hplip 3.17.10 .
'hp-check -i' reports
warning: 12-18.04 version is not supported. Using 12-17.04 versions dependencies to verify and install...
warning: HPLIP-Installation: Auto installation is not supported for 12 distro 18.04 version
Vladimir Botka
  • 283
I had the same error as mentioned above Unable to communicate with device (code=12) You would also notice that "sudo hp-check" reports errors for the scanner.
Googling that error I found a German Ubuntu page suggesting the following fix which also helped in my case (even not knowing German it is easy to follow): https://forum.ubuntuusers.de/topic/hp-deskjet-3636-device-communication-error/
So essentially you only have to run this one-liner:
sudo apt purge ippusbxd
and then unplug/replug your printer. I re-ran sudo hp-check and all errors had gone and scanning worked like a charm.
Cheers
graham
  • 13,061
isbjörnen
  • 31
My Ubuntu 18.04 LTS suddenly got the same error message. Before, the printer worked just fine for some weeks. I solved my problem by observing that the printer, an HP Color Laserjet Pro MFP M280 nw, connected over the LAN, appeared twice in the Ubuntu printer dialog:
  • HP ... M278-M281
  • HP ... M280nw_ ...
The error appeared on the first entry; the second works just fine.
Roland
  • 216
Check your groups (with groups command): lp is required for hplip, not lpadmin only. So:
# usermod -a -G lp $USER
# usermod -a -G lpadmin $USER
The latter may be excess, not sure for that. But the first is required. Keep in mind re-login is requred then.
Boris
For me the problem was the USB port. When I plugged the printer into another USB - then all worked fine :D
This solved my problem in Ubuntu 20.04.3:
https://www.google.com/search?channel=fs&client=ubuntu&q=how+to+resolve+printing+problems+in+ubuntu+20.04
I did the following:
  1. Run the following command in Terminal
  2. Reinstall the printer by going to Settings → Printers.
  3. Then remove all existing printers.
  4. Switch on the printer, connect on USB Port and Add Printer.
I arrived here because I was having the same problem. Turned out my networking was funky.
It was my own fault, I had my laptop (Thinkpad T580 running Ubuntu 20.04 LTS) on both the wifi that the printer was on (HP Color LaserJet CM3530 MFP) and plugged into a POE switch to work on a raspberry pi thing. Unplugged my laptop from the wired network and then things worked fine.
My main complaint is that the error and its handling could have been less cryptic. The document simply didn't print, no error message or feedback. I only found the "device communication error" when I opened up the Printers dialog.
