I have a side-by-side installation of Windows 8.1 and Ubuntu. As I am a pretty helpless user it took me some time to set it up, but it worked and when I start the computer, I get a choice between running the Ubuntu or, if I type "esc" and enter "exit", it jumps to Windows and starts Windows. Today I was asked to update the Linux files. I did, and when I returned after a minute or so Windows was up. ???? I restarted the computer, but now only Windows starts. It is as if Linux never existed - in fact something prevents that the system asks for the choice. Is there something I can change to recover my Ubuntu partition? After I tried to repair GRUB (as given in comment below) I get the following boot loader menu, and I include what happens when I choose any of the options:
Ubuntu => black screen, caps lock blinking, nothing happens anymore no matter which key I press
Advanced options for Ubuntu => same without caps lock blinking
Windows EFI bootmgfw.efi => Windows starts regularly.
Windows EFI Boot UEFI loader => Windows starts regularly
EFI/Ubuntu/fwupx64.efi => the boot loader page is entered again
EFI/Ubuntu/mx64.efi => blue screen “shim UEFI key management” appears, when I press “any key to continue”, another menu “Continue boot/enroll key from disk/enroll hash from disk”, when I choose 'continue boot', black screen as above
EFI/Toshiba/Boot/bootmgfw.efi => black screen as above
Windows Boot Manager => Windows starts regularly
System setup => "error: can’t find command 'fwsetup'. Press any key to continue" => back to boot loader page.
When I start Windows (8.1) and go to the Windows Boot manager, under "using a device" Ubuntu is listed as one option. Choosing this option leads again to the Ubuntu boot manager, so nothing is gained.
The boot repair diagnosis can be found at http://paste.ubuntu.com/p/qv42scvngD/
Heimdal
Windows usually won't typically see an Ubuntu partition as Windows doesn't support as many filesystems as Ubuntu does. This is especially true of the default ext4 filesystem as well as many others. To the best of my extensive knowledge, the only partition types that Windows recognizes on desktop OS's are FAT variants or NTFS. Regardless, it sounds to me like you've somehow lost your boot record or grub configuration. This is in my experience far more likely to happen via a Windows update than any Ubuntu update. (I've seen the former, but never the latter.) To resolve this issue you simply need to repair grub or reinstall grub.
Elder Geek
  • 36,752
