I've got a bluetooth adapter which works fine as a pulseaudio high fidelity playback (a2dp) device in Ubuntu 17.10. The speaker test works fine in the standard sound settings GUI when I connect to bluetooth using headphones. The problem is that Firefox YouTube videos don't use the bluetooth adapter.. they consistently play over the HDMI speaker.
I installed kmix and it says that Firefox is using a Playback Stream - specifically 'Firefox: AudioStream'.
If I vary the volume of the HDMI audio in the kmix Playback Devices tab, it varies the sound level of the YouTube video playing over the HDMI speaker.
The bluetooth headphone also has a slider at max volume in this tab, but the headphones do not receive any sound from the browser. When the headphone slider volume is changed, a pleasing 'thwop' sound is heard in the headphones.
Is there a way to get Firefox to output to the bluetooth adapter?
thanks!
As per @Takkat comment, i found the following steps worked with Ubuntu 17.10:
sudo apt-get update
sudo apt-get install pavucontrol
Within pavucontrol it's possible to designate the BT device for output (once it has connected). If a video with sound is playing in a browser, an entry for the browser will appear in the Playback tab. The bluetooth device can then be specified.
This device is both reasonably priced and seems to work well with 17.10. Just saying.. there was a lack of information when i last looked. https://www.amazon.ca/gp/product/B00E38N7QE/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
