The command gnome-screenshot -c is not copying the captured screenshot to my clipboard in Ubuntu 17.10.
How do I fix this?
The answers in this question do not work for my Ubuntu 17.10
How do I fix this?
Ok, problem solved. The problem was with the default wayland used in Ubuntu 17.10 which somehow affected other commands like gksudo and gksu too. When I logged into Ubuntu with xorg, everything worked perfectly!
If the command isn't working on v17.10 then you can try using shutter.
The steps to install shutter on your system are given below:
sudo add-apt-repository -y ppa:shutter/ppasudo apt-get updatesudo apt-get install shutterOnce you have shutter installed on your system, you can refer to this link for more information - using shutter to copy image to clipboard
Apart from shutter, Ubuntu allows you to use default shortcuts too that help you in taking screenshots. The above link lists down those shortcuts as well.
Regards.
