I recently partitioned my hard drive to install ubuntu 17.10 and to use CUDA. I have run into a non-resolving problem. I have
Followed the exact steps as stated in How can I install CUDA 9 on Ubuntu 17.10. The message I keep on receiving is (after rebooting in insecure mode, and then running the CUDA run file):
***WARNING: Incomplete installation! This installation did not install the CUDA Driver. A driver of version at least 384.00 is required for CUDA 9.0 functionality to work.This makes no sense, as I have successfully installed 384.111 previously. My output when I run
$ nvidia-smiis
NVIDIA-SMI 384.111 Driver Version: 384.111 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | |===============================+======================+======================| | 0 GeForce GT 740M Off | 00000000:01:00.0 N/A | N/A | | N/A 54C P0 N/A / N/A | 261MiB / 2004MiB | N/A Default | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: GPU Memory | | GPU PID Type Process name Usage | |=============================================================================| | 0 Not Supported | +-----------------------------------------------------------------------------+So naturally my next step was to try another method of updating my driver. Attempting to run the run file for the latest driver(I made it executable and ran it with sudo) yielded the error:
ERROR: An NVIDIA kernel module 'nvidia-drm' appears to already be loaded in your kernel. This may be because it is in use (for example, by an X server, a CUDA program, or the NVIDIA Persistence Daemon), but this may also happen if your kernel was configured without support for module unloading. Please be sure to exit any programs that may be using the GPU(s) before attempting to upgrade your driver. If no GPU-based programs are running, you know that your kernel supports module unloading, and you still receive this message, then an error may have occured that has corrupted an NVIDIA kernel module's usage count, for which the simplest remedy is to reboot your computer.So I rebooted and still received the same error. So its either an X server or the NVIDIA Persistence Daemon.
- From there I followed the steps from How to install NVIDIA.run? except I stopped the service gdm3 instead of lightdm, this was to disable the X server. After this I attempted to run my driver file again, but got the same error.
My next attempt was to blacklist the
nvidia_drm nvidia_modeset nvidia_uvm nvidia drm_kms_helpermodules but after rebooting and then running the driver executable, the same error as in bullet 2 occurred.
I have also tried using the preinstalled software Additional Drivers in software and drivers. This seemed to work fine until the same error as in bullet 1 popped up again, after trying to run the CUDA run file.
Where do I go from here? Is there anyway to disable the NVIDIA Persistence Daemon?
