I have installed Ubuntu 16.04 on HP bs179tx laptop, but I am unable to connect to wireless networks. When I checked sudo lshw -C network, it is displaying *-network UNCLAIMED.
Zanna
  • 72,312
Suhas
With a temporary working internet connection by ethernet, tethered or whatever means possible, open a terminal and do:
sudo apt update
sudo apt install build-essential dkms git
uname -r
The last command will give you your kernel version; for example 4.13.0-32-generic. If your kernel version is 4.11 or higher, continue with the following:
git clone -b 4.11-up https://github.com/jeremyb31/rtl8723de.git
sudo dkms add ./rtl8723de
sudo dkms build rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414
If your kernel version is 4.10 or lower, then do:
git clone -b 4.10-down https://github.com/jeremyb31/rtl8723de.git
In either case, reboot and your wireless should be working.
EDIT: The fact that your dkms status shows ‘built’ and not ‘installed’ suggests that there were problems, most likely errors, in the process I suggested. These errors cannot be ignored; they must be identified and fixed before the driver will build and install properly. Let’s start over. If, at any time, there are errors STOP and post them so we can fix it and proceed.
From the terminal:
sudo dkms remove rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414 --all
sudo rm -rf rtl8723de
If there are errors here, STOP and report them.
sudo dkms install rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414
If all goes without error, please check again:
sudo dkms status
We hope you see:
rtl8723de, 5.1.1.8_21285.20171026_COEX20170111-1414, 4.10.0-28-generic, x86_64: installed
If so, try:
sudo modprobe 8723de
Any improvement?
chili555
  • 61,330
