I use a mouse, a 3D-mouse and a keyboard with a lot of extra keys which are mapped via xbindkeys under Ubuntu Gnome 17.04. Now the support of 17.04 is run out and I was forced to switch over to Ubuntu which now uses the Gnome Shell again and additional based on Wayland. This sounds good but the important feature provided by xbindkeys seemed not to be supported anymore as described in this blog.
What is now the proposed alternative way to map extra keys under XWayland?
Alex44
  • 231
Just for the record, in case someone needs a quick recipe for swapping keys on Wayland (done on Ubuntu 18.04 LTS).
I've got a dumb layout on my notebook keyboard, and needed to swap the "right shift" and the "?" keys. So, following the advice from https://askubuntu.com/a/1023182/976363 I simply edited /usr/share/X11/xkb/keycodes/evdev as root, swapping the keycodes for both keys.
    <RTSH> = 62;
    <AB11> = 97;
became
    <RTSH> = 97;
    <AB11> = 62;
The actual key labels depend on your keyboard layout, which should be looked up in /usr/share/X11/xkb/symbols/.
