I'm trying to script an installation of geany and might be on my 20th failure (then like L'Hopital, I shall fail to fail). There's a lot of scripting involved, and I'm only halfway through addressing the issues of missing files.
This Ubuntu Forums post suggests that maybe the ultimate value in this list is what I need:
$ sudo apt  search libglib | grep dev
libglib2.0-cil-dev/xenial 2.12.10-6 amd64
libglib2.0-dev/xenial-updates,now 2.48.2-0ubuntu1 amd64 [installed]
libglib3.0-cil-dev/xenial 2.99.3-2 amd64
libglibmm-2.4-dev/xenial 2.46.3-1 amd64
  C++ wrapper for the GLib toolkit (development files)
Then I go ahead and try it anyways:
$ sudo apt install libglibmm-2.4-dev
[sudo] password for bob:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  linux-headers-4.10.0-27 linux-headers-4.10.0-27-generic
  linux-headers-4.10.0-28 linux-headers-4.10.0-28-generic
Selecting previously unselected package libglibmm-2.4-dev:amd64.
Preparing to unpack .../libglibmm-2.4-dev_2.46.3-1_amd64.deb ...
Unpacking libglibmm-2.4-dev:amd64 (2.46.3-1) ...
Setting up libsigc++-2.0-dev:amd64 (2.6.2-1) ...
Setting up libglibmm-2.4-dev:amd64 (2.46.3-1) ...
but,
$ ldd --version
ldd (Ubuntu GLIBC 2.23-0ubuntu10) 2.23
Copyright (C) 2016 Free Software Foundation, Inc.
This is the output from the install of geany:
checking for GTK... no
configure: error: Package requirements (gtk+-2.0 >= 2.24 glib-2.0 >= 2.32 gio-2.0 >= 2.32 gmodule-no-export-2.0) were not met:
No package 'gtk+-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GTK_CFLAGS
and GTK_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I have to say that I do not understand exactly what it means. If it means that it found 2.0 and needs 2.4, then I would understand.
Also, I find no way to post code doesn't make the whole post unreadable. If I could indent my code 4 spaces, then I wouldn't need to install geany.
muru
  • 207,228
It appears to me that the problem you are having is that you are trying and failing to install geany as mentioned in this comment it's not necessary to compile it as a quick search of Ubuntu Package search makes it clear that the package is available in the Universe repository for all currently supported versions of Ubuntu. To install, simply enable the Universe repository and then issue the commands
sudo apt update
sudo apt install geany
Elder Geek
  • 36,752
I do not know state of the official repositories on your system, so enable them again and fix previous failures:
sudo add-apt-repository main
sudo add-apt-repository universe
sudo add-apt-repository multiverse
sudo add-apt-repository restricted
sudo apt-get update
sudo apt-get install -f
sudo dpkg --configure -a
  • If you need any version of Geany (such as 1.27.1 on xenial), you can install it from official repositories:
    sudo apt-get install geany geany-plugins
  • Geany has PPA, you can install more recent version (1.32) from it:
    sudo add-apt-repository ppa:geany-dev/ppa
    sudo apt-get update
N0rbert
  • 103,263
