Please do not close as duplicate. I have followed the instructions in the other post: How to install software or upgrade from an old unsupported release?
I have also read the Wiki entries, which basically just say "update sources.list, update/dist-upgrade, and do-release-upgrade" just like the post.
https://help.ubuntu.com/community/EOLUpgrades/
It doesn't work; I get the following output:
Reading cache
Checking package manager
Reading package lists... Done
Building dependency tree
Get:1 file:/var/cuda-repo-8-0-local-cublas-performance-update  InRelease
Ign file:/var/cuda-repo-8-0-local-cublas-performance-update  InRelease
Get:2 file:/var/cuda-repo-8-0-local-ga2  InRelease
Ign file:/var/cuda-repo-8-0-local-ga2  InRelease
Get:3 file:/var/cuda-repo-8-0-local-cublas-performance-update  Release [574 B]
Get:4 file:/var/cuda-repo-8-0-local-ga2  Release [574 B]
Get:5 file:/var/cuda-repo-8-0-local-cublas-performance-update  Release [574 B]
Get:6 file:/var/cuda-repo-8-0-local-ga2  Release [574 B]
Hit http://repo.steampowered.com/steam precise InRelease
Hit http://packages.microsoft.com/repos/vscode stable InRelease
Hit http://ppa.launchpad.net/ethereum/ethereum/ubuntu zesty InRelease
Hit http://old-releases.ubuntu.com/ubuntu zesty InRelease
Hit http://old-releases.ubuntu.com/ubuntu zesty-updates InRelease
Hit http://old-releases.ubuntu.com/ubuntu zesty-backports InRelease
Hit http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu zesty InRelease
Hit http://old-releases.ubuntu.com/ubuntu zesty-security InRelease
Hit http://ppa.launchpad.net/js-reynaud/kicad-4/ubuntu zesty InRelease
Fetched 0 B in 0s (0 B/s)
Updating repository information
Third party sources disabled
Some third party entries in your sources.list were disabled. You can
re-enable them after the upgrade with the 'software-properties' tool
or your package manager.
To continue please press [ENTER]
  404  Not Found [IP: 91.189.91.26 80]
Err http://us.archive.ubuntu.com/ubuntu artful-updates/universe arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful-updates/multiverse arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful-backports/main arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful-backports/universe arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful-security/main arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful-security/universe arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful-security/multiverse arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful/main arm64 Packages
Ign http://us.archive.ubuntu.com/ubuntu artful/universe arm64 Packages
Ign http://us.archive.ubuntu.com/ubuntu artful/multiverse arm64 Packages
Err http://us.archive.ubuntu.com/ubuntu artful-updates/main arm64 Packages
Ign http://us.archive.ubuntu.com/ubuntu artful-updates/universe arm64 Packages
Ign http://us.archive.ubuntu.com/ubuntu artful-updates/multiverse arm64 Packages
Ign http://us.archive.ubuntu.com/ubuntu artful-backports/universe arm64 Packages
Ign http://us.archive.ubuntu.com/ubuntu artful-security/universe arm64 Packages
Ign http://us.archive.ubuntu.com/ubuntu artful-security/multiverse arm64 Packages
Fetched 466 kB in 0s (0 B/s)
Error during update
A problem occurred during the update. This is usually some sort of
network problem, please check your network connection and retry.
E:Failed to fetch
http://us.archive.ubuntu.com/ubuntu/dists/artful/main/binary-arm64/Packages
404 Not Found [IP: 91.189.91.26 80], E:Failed to fetch
http://us.archive.ubuntu.com/ubuntu/dists/artful-updates/main/binary-arm64/Packages
http://us.archive.ubuntu.com/ubuntu/dists/artful-backports/main/binary-arm64/Packages
http://us.archive.ubuntu.com/ubuntu/dists/artful-security/main/binary-arm64/Packages
404 Not Found [IP: 91.189.91.26 80], E:Some index files failed to
download. They have been ignored, or old ones used instead.
Restoring original system state
Aborting
=== Command terminated with exit status 1 (Sat Jan 27 17:47:46 2018) ===
Unfortunately, I can't copy the middle bits within the "......" because the upgrade process launches some sub-terminal process that doesn't allow scrollback (my normal Screen escape-and-scroll doesn't work, so who knows what this is?)
The problem seems to be that us.archive.ubuntu.com/ubuntu/ doesn't actually have artful archives?
Clarification added after some comments below:
  • the problem seems to be that I added multi-arch support for arm64 to support cross compilation to Jetson TX2 (thanks!)
  • this, in turn, doesn't work with automatic mirror selection, because many mirrors only mirror Intel architecture (why can't apt find an appropriate mirror?)
  • suggestions to change the mirror used confuse me, because I can't find any documentation on how to convince do-release-upgrade to to use a particular mirror (I did use the Googles for 20 minutes; the closest I could come was how to point it at my own full archive mirror, which I neither know how to set up nor desire to set up)
  • do-release-upgrade is specifically documented to swap out the sources.list file that exists on the system, meaning any local edits I do don't apply to the release upgrade
So, the question is now: How can I convince do-release-upgrade to use a specific mirror (or central archive) that has all the appropriate architectures?
galoget
  • 3,023
Jon Watte
  • 526
Most Ubuntu mirrors are of x86 (i386 arch) & x86_64 (amd64) only, and don't include the many other architectures like arm64. So you have two options
  • use only the main mirror archive.ubuntu.com/..
  • add a restriction to use only x86/x86_64 in the country.mirror
An example of the second option is
deb [arch=amd64,i386] http://us.archive.ubuntu.com/ubuntu artful ....
guiverc
  • 33,561
I had this same issue when trying to run do-release-upgrade on an actual arm64 machine.
In the end, I followed the instructions in this answer to download the (in my case) artful.tar.gz upgrade package:
cd somewhere
curl -LO http://archive.ubuntu.com/ubuntu/dists/artful/main/dist-upgrader-all/current/artful.tar.gz
curl -LO http://archive.ubuntu.com/ubuntu/dists/artful/main/dist-upgrader-all/current/artful.tar.gz.gpg
gpg --verify artful.tar.gz.gpg artful.tar.gz
# this will fail, download the key:
gpg --keyserver hkp://keyserver.ubuntu.com --recv-keys 0x...
tar xf artful.tar.gz
Then, remove everything from the mirrors.cfg file, and then only add:
http://ports.ubuntu.com/ubuntu-ports/
Now, run
./artful --mode=server --frontend=DistUpgradeViewText
to start the upgrade process.
I don't know how I ended up in this situation, it seems unlikely that do-release-upgrade shouldn't work on non-x86/x64 Ubuntu installations.
m01
  • 141
