-1
I am working to build a reinforcement agent with DQN. The agent would be able to place buy and sell orders for a day trading purpose. I am facing a little problem with that project. The question is "how to tell the agent to maximize the profit and avoid the transaction where the profit is less than 100$".
I want to maximize the profit inside a trading day and avoid to place the pair (limit buy order, limit sell order) if the profit on that transaction is less than 100$. The idea here is to avoid the little noisy movements. Instead, I prefer long beautiful profitable movements. Be aware that I thought using the "Profit & Loss" as the reward.
"I want the minimal profit per transaction to be 100$" ==> It seems this is not something that is enforceable. I can train the agent to maximize profit per transaction, but how that profit is cannot be ensured.
At the beginning, I wanted to tell the agent, if the profit of a transaction is 50 dollars, I will remove 100 dollars, then It becomes a penalty of 50 dollars for the agent. I thought it was a great way to tell the agent to not place a limit buy order if you are not sure it will give us a minimal profit of 100$. It seems that all I would be doing there is simply shifting the value of the reward. The agent only cares about maximizing the sum of rewards and not taking care of individual transactions.
How to tell the agent to maximize the profit and avoid the transaction where the profit is less than 100$? With that strategy, what guarantee that the agent will never make a buy/sell decision that results in less than 100 dollars profit? Does the sum of reward - # transaction * 100 can be a solution?
fgauth
  • 189
I want to maximize the profit inside a trading day and avoid to place the pair (limit buy order, limit sell order) if the profit on that transaction is less than 100$. Be aware that I thought using the "Profit & Loss" as the reward.
To me this implies that your profit per transaction is not the true reward function that you should be using. You don't say directly in the question, but presumably there is some per-transaction cost, tax or other issue which means that these low gain transactions are not desirable.
The answer is to find a more accurate reward function. You have suggested a quick fix of subtracting a fixed offset from the reward. This should have a desirable effect of limiting borderline buy/sell arrangements and meeting your constraint, so I would suggest trying it. The main issue I see with it is that you may have changed the reward function so that it doesn't truly reflect your goals.
A better approach is to look more carefully at the problem and your goals at a higher level. There must be a reason for wanting to avoid these smaller profit transactions. What is it, and can it be expressed itself as a reward? For instance, if there will be a transaction fee, include that. If the fee structure or reasoning is complicated or appears delayed or aggregated over many actions, then this makes optimisation harder, but RL is actually designed to cope with this. You could for instance only reward the agent with profit/loss after a group of actions covering a whole day's trade. You would then rely on the learning algorithm to figure out which states and actions combined to generate the observed reward.
If there is an unknown or random difference between predicted and actual financial gain then no amount of juggling the reward function gets around that. For RL, learning about and predicting expected gains is "built in", but that does not mean that this task becomes easier - in fact if prediction in the problem is hard, you may be better off focusing on that and forgetting RL at least initially. Your question is not clear on that, but if you want to avoid risk whilst learning, you should bear in mind that a simple hard rule would likely interfere with the ability of RL to work. At its heart RL is a trial-and-error learning system. Errors should be expected, and are required for the system to learn where best the balance point is between risk and reward. Of course that doesn't help you if the learning system would deliberately make you bankrupt exploring what happens when you sell things at a loss - there are likely to be ways to avoid that and still achieve your goals, but you will need to explain more about your system in a different question.
Neil Slater
  • 33,739
  • 47
  • 66
I would use the proposed fitness function defined in your other StackExchange question. I would then inflate the buying price used in the equation by \$100, and leave the selling price as the price the shares were sold for. This would only reward a trading rule when profit is greater than \$100.
If you want to minimise spike it might be best to normalise the data going into your learning algorithm, for example use an x day moving average instead of the actual share price.
Jason
  • 436
  • 13
