24
I'm looking for a software that helps me develop and organize the characters for my novel.
What I want:
  • something like a filesystem, with a file for each character
  • it should have or allow me to create categories like name, gender, age, backstory, and so on
  • once created, these categories should automatically be available for each character
  • adding images, text files, movies and stuff, or linking to these
  • it would be nice if it somehow interacted with my writing and timeline software (Scrivener and Aeon Timeline)
  • creating relations between characters (married to, boss of, lives next door to, etc.)
  • these relations should not be limited in number
What I don't need:
  • character development from archetypes (as in Persona) or a list of mental disorders (as in Character Writer)
What I know of:
  • Persona: looks nice, but has these stupid character development tools that I don't need
  • Character Writer: looks awful
It does not have to be specialized software, but something with the above functionality. If you know of some software that does all that but has some other originally intended purpose, that's fine, too.
Update
After some experimentation I have found that a spreadsheet works best for me. I use Excel, because I have it, but will try other speadsheet software before my next project.
In the spreadsheet, each column is a character and each row is some aspect of that character, such as traits (name, height, personality) and structural elements (development). For every story I write, I can create how many and whichever rows I need. For example, in some stories the outward appearance will be more important, so I will have rows for eye color, clothing style, and which part of their body hair they don't shave; in other stories the past of the characters is more important so the backstory row will be split into many other rows such as kindergarten, relationship to siblings, or summer camp in 1963. Colums can be added and moved around, too, which is nice if you want to see different characters side by side and work to make them more different or explore their relationship.
I even partly develop character arcs in the spreadsheet. This question contains a (made-up) example of what this might look like: Outliner (software) with annotations for OS X or browser based (but offline!) For more detailed work on the character arcs, I switch to pen and paper and draw the kinds of graphs I have mentioned here: To visually and logically plan out stories
What I dislike about Excel are:
  • the vast functionality that is unrelated to writing text into cells, which makes the program cumbersome to use for this purpose
  • the visual clutter that comes from this functionality
  • the height limit on cells
  • limited or awkward styling and editing options (e.g. newlines within cells or alternating background adapting to newly added rows)
Despite these drawbacks, I find using Excel to create characters very helpful. Unless I can find a better tool, such as a spreadsheet for text or a text editor with columns and rows, I will likely stick with it.
wetcircuit
  • 29,603
  • 51
  • 129
13 Answers13
20
Custom Meta-Data in Scrivener. You can do some custom fields in Scrivener. See the "Custom Meta-Data" button at the bottom of the inspector (it looks like a little tag). Here's a photo where I added a few fields:
Custom metadata fields in the inspector
You can add fields by clicking the gear button.
When you add a metadata field, it becomes available for all documents in the project.
You can also view these fields in the outline:
Custom metadata fields in the outline
You can put multiple paragraphs into the fields if you want, but I prefer subdocuments for that.
Fields appear in all docs. You probably don't want custom character fields in your plot outline, and vice versa, so that might nudge you to keep characters in a separate project. Dunno.
Limited support for relationships. This custom metadata feature doesn't let you easily add relationships from one character to another. In my outline photo, you can see a simple relationship, but it's just a text field. You can't navigate it in both directions (uh, or in either direction).
Relationships via wiki links. Over time, I found that I could create the relationships I needed as "wiki" links from one Scrivener doc to another. I'd have to add a link from each related doc to the other. And if the relationship changed, I'd have to edit both docs to express the new relationship.
Relationship docs. For significant relationships, I often create a Scrivener doc for the relationship. I put the "relationship" doc into the folder with the most important character. This gives me a place to put all of the details about a relationship. As long as the relationships (who relates to whom) are reasonably stable, this works well.
Super NoteCard. A few years ago I used an app called Super NoteCard. It wasn't great for writing, but it was much more flexible for organizing things. I remember that it allowed arbitrary relationships among cards.
Dale Hartley Emery
  • 24,167
  • 41
  • 83
14
I suspect people will object to me saying this, but still, wanted to give some food for thought:
Why not just keep plain text files, or documents made in whatever word processor you prefer?
I'm 32, and I've been writing on a computer since I was 18, so I have about 14 years of character and worldbuilding documents built up, for several different universes.
The trouble with deciding to put your character or world information in some flavor of software-of-the-month is that it tends to store data in a custom database or flat file schema. As you write more and more, and years pass, you are putting yourself in a position where, if the data format the software you use isn't easily transferable to a newer program, you can abruptly find yourself in a position where your old data is difficult to access because your operating system changed, doesn't support your old program, and nobody bothered to program an easy data migration path for YOUR software to whatever the new thing ends up being, because it was so niche.
You'll be more insulated against this sort of issue if you decide on a naming scheme and just keep text files, or word processor files, on your hard drive or cloud drive in some sort of order. Since word processors in general are so widely used, you KNOW there'll always be a way to convert text files or word processor documents to another format, and it probably won't be all that painful. But if you start using really custom software, you might be in a frustrating position later with your worldbuilding and characer data.
Or...you might not--maybe you're technical and you don't mind doing data migrations. I'm technical and not afraid of software and honestly I still think they're a PITA and time-consuming. I'd rather spend my time writing than sorting out my data and putting it into a new format.
I just wanted to give some food for thought before you or anyone tries to pick software thinking it'll work wonders for the writing process.
Writing really comes down to words on a page...fancy databases are often good timewasters but can distract you from actually writing, and in the long term can make your old data difficult to access if you want it later.
Zwi
  • 286
Scrivener has features that can be used for this, specifically, templates. You can put all your character notes in one file and use that as a template for other characters. Or, if you insist on having them in separate files, you can create a folder for each character, but you might need to manually copy each file for each new character (may be as simple as an Option-drag).
The major thing missing would be the relationships between characters.
Alex Feinman
  • 293
As requested, here is a little more insight into Charahub.com. It's a website intended for writers and artists to store and/or share their characters in a central location.
Screenshot of Charahub's user profile
Free accounts have a limit of a hundred characters upon signing up. Additional characters may be earned through referral. You can divide characters into user-created groups.
The profile and question sections have set questions that you can fill out. I believe user-created questions is in development right now.
You expressed some concern over privacy. Charahub sets your character profiles as public by default, but it's easy to change. I tested this specific feature by searching for my characters. I can confirm that it worked as expected. Once set to hidden or private your character profiles are no longer searchable.
Free accounts are able to upload ten images per character, each image with a max image size of 500KB
The panel called 'Links' is a flexible way to create relationships between your characters.
The features you were looking for that are not in Charahub are:
  • The ability to create new questions and/or categories.
  • The ability to add videos and/or text files directly into the document.
  • Any function that relates to third-party writing software, such as Scrivener.
  • Limitless character creation, the maximum for free accounts is a hundred characters. For gold accounts ($3/mo) you get 250 characters, 25 images/character with max image size of 1024KB, no adverts, and priority support.
Lastly, this website is in its infancy, so it's not a known quantity. If it works for you, excellent, but definitely take precautions. Back up your work to an offline location.
Terri M.
  • 296
You may want to have a look at KeepNote. It's open source and runs on a number of different platforms (Windows and Linux packages are available), but it doesn't do everything you want out of the box. To address your particular considerations:
Pretty well check: it allows you to create categories and subcategories to organize your data any way you prefer, and it supports categories with and without text (as "pages" as KeepNote calls them can contain subpages as well).
Check: just create another page (as a sibling or child to an existing page) to put the information into.
No do. It can probably be done with a plug-in, and Import Folder Tree looks promising at least as a starting point, but it isn't done out of the box.
Pages are (X)HTML web pages so in principle you can add anything that can go onto a web page. The built-in editor is somewhat minimalistic but does include many of the basic features for text editing.
No do, at least out of the box.
You can make a separate page or set of pages for relationships that describe them, and KeepNote supports full-text search, but there is no native support for something like this that I know of.
One nice thing about KeepNote is precisely that it keeps its data as HTML files along with some XML metadata files in a simple file system directory hierarchy, so backing up your work, working with the files in different software etc. is trivial.
user
  • 3,754
  • 27
  • 43
I am looking for similar software and i'd be interested to know if you've found anything since you asked this question. The only thing i've found in my search is a piece of software called WriteItNow.
In regards what you were seeking, this is what i've learned about WriteItNow from their Demo (which, by the way, does not allow you to save... so i didn't get that deep into the software):
It appears to be project-based, somewhat like Scrivener... so each character has their own page, but it's all contained in one project file. However, unlike Scrivener where the .scriv file is really a folder, the WriteItNow .wnwx file is just a single file... so it wouold probably be good practice to export the data from the file on a regular basis... just in case.
It generates a blank form for every new character, with tabs for Personality Traits, a Picture, Relationships, and written details.
Under the "Details" tab for a specific character, clicking "Links" in the menu will allow for linking to files, websites, and other information within the project.
Not directly, but it allows for exporting to basic formats (doc, pdf, txt, rtf, html, epub). It also allows you to print the charts it can generate (such as the relationship chart).
creating relations between characters (married to, boss of, lives next door to, etc.) these relations should not be limited in number
Allows for unlimited relationships and relationship types as far as i can tell. Also allows for the creation of custom relationships. And it generates a relationship chart.
Here's a screenshot of the Characters Tab: enter image description here
Adia Aira
  • 41
Just wanted to mention The Novel Factory here, as keeping track of characters was one of the main reasons it was developed.
Disclosure - I am the creator of this software.
This is a screenshot of the Character Overview section, where you can see a list of all your characters, with key information displayed:
Novel Factory writing software character overview
Then you can open up each of the character 'cards' and record tons more detail about each of them:
There are various templates to prompt your character development:
The Novel Factory is free to try, to see if it's what you're looking for:
SnootyShrimp
  • 3,567
  • 16
  • 22
Though I write in Scrivener I keep track of my characters and their relationships in MacFamily Tree, a geneology app. Works wonderfully for me.
Suzanne
  • 31
I think Scrivener answers your needs almost completly if not to all of them. It has a very good system to understand and keep up with your characters. Furthermore in my opinion, it is a great software to develop and write your stories.
I would recommend giving yWriter a try. yWriter is a full novel writing tool, similar to Scrivener. It allows you to create character summaries and it can track a characters progress through the story, IE what scenes and chapters he appears in. It is also FREE.
JohnBlood
Scrivener is the big one that I'd recommend. However, and this is more for screenplays but does have some stuff for comics, novels, and more is Celtx which I used a while ago, but haven't used recently. It had some note taking functionality and character functionality with it and it has a nice price point of being free.
The Scando
  • 211
The base templates in Scrivener is horrible. They can be changed to be a bit more suitable, but the template changes are on a per-project basis. I would recommend making a blank project, making all of the changes and additions that you'll find that you want in most of your projects and then saving that as a starting place. You would then obviously "Save As" a different project for each of your projects though.
Honestly, I wish I could have an all-in-one tool that would combine all of the best features of Scrivener, Persona, Word, and believe it or not, Articy Draft.
Dave
  • 26
I personally use forteller for my database. I can input custom slots for each character which becomes available for all the others. You can also add locations,character groups, and even pin boards. All items can be connected though links which allows character relationships to go explained. Highly recommend cause it is free as well.
