I'm a writer—no programming, only prose in text files, mostly in Emacs org-mode, some in markdown-mode.
I want to implement a version control system for my writing projects.
I work with two types of text files:
- drafts (textfile-v1.org, textfile-v2.org, etc)
- research files (research-notes.org)
The latter, the research files, consist of hunks of text I have copy and pasted from the web. My workflow for the research files involves going through those files and deleting as I go. In other words, when I find a quote, I might copy it into a draft file, then delete the quote. This is my way of knowing what I have already processed or not. So that by the time my research file is blank, I know I'm done. When the research file is blank, I delete it so I know I'm done.
For both these uses—writing multiple drafts, and destroying research files as I go—it strikes me that having a version control system would be helpful.
I am NOT doing different branches as I go—just going forward as I make progress writing my book.
I'm using Aquamacs Emacs on OSX. Which version control system would you recommend, and how would I go about integrating it with my Emacs workflow?
