How to format a transition between two paragraphs?
  • At the end of the first pg
  • Standalone
  • At the beginning of the second pg
What about indents and line breaks?
Thanks!
[First paragraph content.]
Here are preliminary remarks.
[Second paragraph content.]
Ben
  • 19,064
  • 16
  • 72
In print
In a printed book, to visually indicate the transtion from one paragraph to another,
  • begin the new paragraph on a new line and
  • indent the first line of the new paragraph, if the paragraph is not the first in the chapter.
Chapter Title
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed eiusmod tempor incidunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquid ex ea commodi consequat. Quis aute iure reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint obcaecat cupiditat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
Indenting the first line of a subsequent paragraph helps readers identify the beginning of a new paragraph when the last line of the preceding paragraph fills the full width of the text block and there is no visual "gap" at the end of the line. The first paragraph in a chapter is not indented, because it doesn't have to be set off from a preceding paragraph.
There is no difference to this practise at the beginning or end of pages. Indenting the first line of a paragraph that is at the top of a new page indicates that it is a new paragraph and not a continuation of the last one on the preceding page.
To indicate a section break,
  • insert a blank line between paragraphs and
  • indent the first line of the new section.
Chapter Title
When the section break coincides with a page break, that is, when the section break is at the bottom or top of a page, insert three asterisks centered on the page:
Chapter Title
26
Online
When publishing text on the internet, it is the convention to insert a "gap" between paragraphs:
Chapter Title
This makes it easier for readers to identify paragraphs on a computer screen and less exhausting to read online.
Note that the gap is not a blank line but a margin or padding. You can verify this by copying the example above (or all the text of my answer) to a text editor.
On the internet, all section breaks are indicated by three centered asterisks.
Notes
In the examples, I have emulated the indentation and centering with a series of non-breaking spaces ( ), because this website does not allow users to use CSS indentation (text-indent: 1em;) or centering (text-align: center;). Do not use spaces for this purpose when layouting text for print or for publishing online.
To understand paragraph formatting, it also helps to just open a book you own and look at it ;-)
Ben
  • 19,064
  • 16
  • 72
