ABOUT THE DASH ON YOUR KEYBOARD . . .
Dashes on the keyboard
The default dash key produces a hypen (-). Different dashes are achieved by either inserting them as a symbol or using a keyboard shortcut. Alternatively, people can search for the dash via Google and copy-paste the desired dash in (changing formatting and font as needed). Some keyboards do not have additional keys or straightforward signposting of symbols.
Using shortcuts on keyboards
Modern keyboards tend to show at least two symbols on the main dash key. The lower symbol is the default symbol you achieve by pressing the key; the higher symbol on a key is the alternative symbol you achieve by pressing and/or holding other keys (a keyboard shortcut). Just as you might [Ctrl] + V to past a copied selection, you can (on a Mac) do the following:
- Just press the dash key for a hyphen (-)
- Hold [Option] and press the dash key for a en dash (–)
- Hold [Option] + [Shift] and press the dash key for a em dash (—)
NOTE: I say a and not an because "a" refers to a singular quantity whereas "an" refers to a subject-context even if referring to an object (i.e. an before a vowel and silent consonant is not the correct rule, which is determined by context specific usage not "phonetics" ).
Identifying errors of usage
Word processors like MS Word have in-built correction features, which are unreliable. Just as some correct terminology will be flagged by the limitations of the dictionary is use, so too will the flagging of punctuation be limited to the basic rules applied in the software. The greater the complexity of the writing, the less reliable in-built correction software becomes because language is complex. Do not rely on the software – make your own judgement call on anything flagged. Alternatively, you can cross-reference with an appropriate style manual or just read on . . .
KNOWING WHEN A SPECIFIC DASH IS CORRECT
Types of dashes
There are three dashes used in writing: the hyphen (-), the en dash (–), and the em dash (—).
A matter of length
While a dash separates or modifies the meaning of text or numbers, it is the length of the dash that signifies how it should be read in context. Hyphens are half an en; en dashes are half an em. The en and em are units of measure. In maths, the minus symbol is represented by a hyphen and sometimes an en dash, but the latter is usually more a case of how a font may not differentiate "dash length" very well.
What is a hyphen?
A hyphen (-) is typically used to make compound words (e.g. blue-grey) where there isn't an existing one (e.g. football). Sometimes, writers will forgo the hyphen on compound words as a way of signifying to the reader a word is common in their story world (e.g. levcar).
A double hyphen (--) is a way of constructing an em dash, which has its origins in the days of the typewriter. With old typewriters, there were fewer variations of symbol and punctuation. The double hyphen has fallen out of common use, but if you do use it, then just be consistent.
Examples include:
- dragon-like (i.e. The statue was dragon-like)
- fish-that-cannot-swim (i.e. My kid was a fish-that-cannot-swim type)
- Smith-Doe (i.e. Jane hyphenated her name to Smith-Doe after marrying John)
- 0 - 4 = -4
- 01-01-2025 (i.e. 1 January 2025 can be written as 01-01-2025)
What about en dashes?
The en dash (–) tends to be used to strongly emphasise a point at the end of a sentence (e.g. We were ordered to kill the prisoner – I refused). In the context of quantity, it can convey that there is a range (e.g. April – June). It can also signify a connection or relationship between two distinct subjects/objects where subjects can be concrete or abstract.
A double en dash is used to represent missing letters in a word (e.g. B––t as in boat), which is typical in a game of Hangman or in word-based puzzles.
Examples include:
- We do not agree with simple explanations – we hate them!
- We are traveling 24–28 January this year
- The score was 4–3 and we won
- The parent–child relationship is varies across cultures
- A work–life balance is important
- E– d–shes (i.e. the 'n' and 'a' letters are withheld)
And em dashes?
The em dash (—) often signifies a break, break away, or interruption where suddenness can be emphasised to the reader by removing the spacing. The em dash can also be used in reversed listing rather than standard listening, which uses a colon (the first listed subject/object denoting greater importance).
A double em dash (——) can represent an omission.
Examples include:
- There is much in this report — forgetting your behaviour — that I like
- We must always be vigilant—
- "My favourite dash is—"
- The document was signed by F——
- Red, blue, and white — these are the colours of the American flag
Dashes in childhood education
Teachers tend not to teach variations of dashes to children in mainstream schooling. So, the hyphen is used for the en dash whereas the em dash is not taught at all. This is a failing of the education system.
