If a person is giving instructions to separate individuals and it's all spoken in quotes, should the spoken words for each new person start a new paragraph or if the commands are connected to a single theme, should they all be together in a single paragraph?
For example, should this be in one paragraph:
Marc realized time was short. "He's bleeding. It's bad. Joan, go get the bandages from the cabinet. Steve, look for a pair of scissors so we can cut open his clothes. Beth, grab the bottle of Everclear from the bar. Oren, call 911."
or should each new addressee get a new paragraph:
"Steve, look for a pair of scissors so we can cut open his clothes.
"Beth, grab the bottle of Everclear from the bar.
"Oren, call 911."
I can't find anything in any style guide on this, so I suspect it's a matter of personal preference, but just as likely that I'm just not searching properly and missed it. If there is any general standard or rule on this, I have no need to pave new ground and would prefer to just go with the standard, recommended method.
In my view, either is correct. The two factors that I would consider in selecting either alternative are:
One, how urgent do you as the author want it to sound; orders in a single paragraph signal urgency and perhaps confidence whereas orders in separate paragraphs signal deliberation and maybe lack of confidence.
Two, what do you as an author want to embellish the speech with physical context such as movement, posture, facial expressions, and so on; It is hard to do that in a single paragraph, and easy to add those factors within the context of each interaction in separate paragraphs.
A single paragraph speeds up the narration and multiple paragraphs slow down the narrative flow.
JonStonecash
  • 5,267
  • 25
To break it off into paragraphs is to imply that there were breaks in the speech. If the commands were rattled off one after the other, it would make more sense to have no breaks. To break as you do would at least imply that the speaker did something such as look at each person in turn while giving orders.
Mary
  • 9,904
  • 18
  • 53
In the above statement, the order should be given in a single paragraph format UNLESS the person issuing the orders is performing some other action between each order or the person receiving the order replies or acts in some fashion. In the above situation where your characters are in an emergency that requires first aid and EMS activation, someone with proper training should be keeping their immediate attention on the victim (vic) and issuing the orders in a firm, uninterrupted voice, which would best be written in a paragraph (The purpose for this is twofold... first, they need to make sure they are heard... some of the orders are given may be to give people who don't know what to do... or are themselves panicing, something to do that is helpful, but keeps them out of the way. The second is doing so without pausing for back talk creates an illusion of command in the situation, which keeps everyone on a single plan.).
As mentioned in my comment, first aid will have some almost trained to give a 911 command first... When I was trained as a life guard, we were taught to identify the parents of children victims as the person to go call 911 and tell them to stay on the phone with the operator until EMS arrives, and wait in the office for further instruction before we gave any other instructions to anyone. The reason for this had several parts. First, the parent is going to know the child's medical history better and will be better able to inform inbound EMS about any medical complications they need to know about. Second, because if its bad enough that we need EMS, the parent is going to be the closest to panicing and that's not going to do anybody any good... and third, because if we're calling EMS then what the lifeguards are trained to do is make every effort to keep the vic alive until EMS arrives and takes over. And CPR, when performed correctly, is not something that will help calm the panicing parent at all and panic is not going to help at this point.
That's more knowing your subject than actual writing technique. Unless someone does or says something in-between your individual orders, keep them in a paragraph."
hszmv
  • 13,474
  • 30
I can vaguely recall instances where authors would combine all the instructions into one (ungrammatical) run-on sentence to indicate the complete lack of breaks, even natural pauses for breath.
On the other hand short paragraphs can also be interpreted as a rather punchy delivery, with a natural emphasis on the name at the start. That would be even more true for much shorter, almost staccato, orders, which follow nicely from Marc's first two sentences:
"Joan. Bandages. In the cabinet.
"Steve. Scissors. We need to cut open his clothes.
"Beth. Everclear from the bar.
"Oren. Call 911."
The names could be followed with an exclamation mark; that would be a good match to how orders might be given in an urgent situation, barking out the name to get attention.
Chris H
  • 161
