I am reviewing a research paper. In the reference section of the paper, the authors have mentioned two previous works that are based on the same topic:
  1. Author X, Author Y, Author Z, "Topic_Name" appeared at ABC conference 2020.
  2. Author P, Author Q, Author R, "Topic_Name" appeared at MNO conference 2020.
In the introduction section, the authors used the following sentence:
"Author X and Author P [1,2] began the study of the Topic_Name."
They did not use "et al." when using this statement. Is this allowed? since it looks as if Author X and Author P are the only authors and they worked in collaboration to study the topic.
These conventions and style will depend on the venue (journal or edited volume). In my field, it is necessary to always acknowledge that there are multiple authors for a given work when referencing it inline. The two primary options I know are:
  • et alia (et al.) meaning "and others" Example: Author X et al. and Author P et al.
  • "and colleagues" Example: Author X and colleagues as well as Author P and colleagues.
If et al. is appropriate for the venue, it is probably thriftier expression when dealing with consecutive multi-authored works as is the case in your example. As a reviewer, you may simply suggest to the author that they rephrase acknowledgement of multi-authorship using the conventions of the venue. The manuscript author can then either look in the venue for examples or consult with the editor if questions persist.
ncraig
  • 166
