23
I've just written such a paragraph:
He turned around and started walking to the nearby store. He bought a bread and a yoghurt. Then he came back and gave the groceries to the homeless guy.
There are several points to this text:
  • I feel like all this is necessary. I want to get from the point where main character talks to homeless person to the point when he gives them food. Skiping any of the actions may confuse reader as it would sound as hero conjured something out of nowhere.
  • I don't see anything worth mentioning here. The description of the surrounding was already given. There is no side story to this thread. If I add anything here it will feel like a filler to me.
  • I'm not sure about English, but at least in my motherlanguage it sounds terrible due to the high count of verbs. This speeds up the pace unintentionally and may confuse the reader.
Overall I think this paragraph sounds extremally bad, but I can't find a way to alter it. I will appreciate any idea on what can I do with such a snag.
Rico
  • 609
  • 13
8 Answers8
55
Add Spices and Mix:
I think the problem is you are thinking of your writing as infodump. Not all infodump is always bad, but admittedly no one really likes it. But it doesn't need to be infodump.
What you should do, however, is figure out what the scene adds to the story and integrate the details into a cohesive whole. The content that makes it essential should be visible in the paragraph, and convey the story goals. Your paragraph is black-and-white, so add color. Every paragraph is an opportunity to make your story come alive. I don't know the rest of the story, so let's make some examples up.
The sight of the homeless man filled him with guilt, and he couldn't bring himself to go on. Ted turned around and walked back to the store, buying a cheap loaf of bread and a small yoghurt. He resumed his walk, dropping the groceries off with the disheveled old man as he walked by.
This brings color to an otherwise perfunctory scene, and explains the motives of the character. Ted satisfies his guilt about the homeless person with a minimal gesture. It integrates MORE detail, which ends up making it more intense.
Ted turned excitedly. The supplies at the store were barely adequate, but Ted bought the nicest loaf of bread and decided that adding the yoghurt would make a sufficient offering. He returned, and humbly set the groceries before the man who appeared as a simple beggar.
This gives a whole different perspective on the same exact scene, where the motives and implications of the scene are completely different. Here, Ted recognizes the 'homeless' person as something special, to be given homage.
Ted snapped his fingers and hustled back to the store he had just passed. He grabbed the only bread and yoghurt on the shelf. As he walked on and studied the labels, he frowned. He almost tripped on the homeless man, and decided to give the food to the bum rather than throwing it away.
All of these are the same events you describe, but each sets a completely different scene, tells you different things about your MC, and creates a rich vision of the events as they happen.
DWKraus
  • 13,757
  • 24
  • 65
20
Compare your paragraph to
He went and bought a bread and yoghurt for the homeless guy.
This is omitting a little bit of information compared to your paragraph: I don't specify that the grocery store is located back where the protagonist came from, and nearby. This may vary from place to place, but I'd expect a grocery store to be nearby in an urban setting anyway.
If the store's location really matters, you'd want to say much more about it anyway. What kind of store is it? How does the neighbourhood look like? If details of the act matter, maybe it also makes sense to include what kind of bread and yoghurt - store brand or something fancy?
There also is some stuff I don't explicitly say. My sentence doesn’t rule out that the protagonist went to the farmer's market instead of the grocery store. Or that he for some reason is prevented from handing over the groceries. Or that he orders the groceries delivered, rather than doing it personally. But the reader will assume that if anything interesting were going on, then you'd tell them. You don't need to do the boring stuff. If it is also established that there is a grocery store nearby, that'll be where you'd expect the protagonist to buy.
Laurel
  • 4,283
  • 13
  • 42
Arno
  • 624
The reader must understand what happened, which is why I mentioned every action the character made
I want to question this, because I think it's a big driver of bad writing. Why are the actions important? Are they interesting actions? No. Do they explore the character? Well, not the way you've written them. DWKraus has explored how you can address those, but you could just delete the entire paragraph.
The only case I can think of where a highly detailed explanation of mundane actions is important is crime fiction, where the reader is primed to interpret details as clues and it will matter later on - "Why, on the morning of June 12th, did you buy a yogurt when in your earlier witness statement you claimed to be lactose-intolerant?"
Edit: if you put the decision do the action, then a paragraph break, and then a description which implies the action happened, the reader can infer that the action happened.
On a whim, he decided to buy some food for this guy.
"Thanks", mumbled the guy between mouthfuls of bread.
pjc50
  • 580
If it's a drudge to write it, it is a drudge to read it. I (as a reader) don't want to read this:
That is a drudge to read. It tells me unneeded details of mundane things - and honestly, it leaves out even more mundane details. If you have to tell me that he walked to the store, then don't you have to tell me that he got there and went through the store to the bakery section to get the bread then to the dairy section for the yoghurt? Don't you have to tell me he stood in line at the checkout and paid for the stuff? You left those details out because they aren't important, and you can leave out the detail about walking to the store because it isn't important, either.
You don't want to just tell people the boring things. You want to tell people the important things and let them assume the dull stuff happened.
Fred was early this morning. He'd slept poorly and gotten out of bed early to escape the nightmares. At this rate, he'd have to wait an hour for the gates at the machine shop to open so he could get to work.
To kill time, he took a detour through a part of town he usually avoided. It was dangerous at night, but safe enough during the day time - the drug dealers and other criminals tended to sleep in.
He'd spent enough time here to know how dangerous it could be - he'd escaped the danger and the poverty, but he hadn't forgotten the hopelessness or the hunger. He'd never get rich working at the machine shop, but he didn't have to wonder where his next meal was coming from.
His feet led him through the streets to a place he knew all too well. He'd huddled there in the dark on many a hungry night. As he passed by, he glanced down the alley with the abandoned crates and dumpsters where he'd often hidden and caught sight of a rumpled looking fellow trying to keep warm in a nest of old newspapers.
Fred thought "Poor bastard. Nobody ever helps anybody around here."
Well, why not?
Fred patted his back pocket - his wallet was there, with the remains of the twenty bucks he'd used to buy groceries the day before. A look at the clock on the jewelry store down the street showed he still had more than enough time to get to work.
A hot cup of coffee and a sandwich, and maybe one more homeless, hopeless loser would find the strength to get up and leave this nasty place in search of a better life.
"Yo, dude. How'd you like a bite to eat?"
The rumpled figure under the newspapers reached greedily for the sandwich, trying to eat and say "Thanks" at the same time.
Fred hunkered down with the coffee cup, and waited.
From there, Fred and your homeless person can get into a conversation.
Fred didn't explicitly go to the grocery store, but it is implied that he did.
I don't care that Fred went to the grocery store. I want to know why he was someplace with homeless people and why he stopped to help one.
I don't know what lead your character there. Tell me about that, rather than the boring "walked to the grocery store, bought stuff, gave it to somebody."
As a reader, I'm fully capable of figuring out that your character isn't walking around with a loaf of bread and a cup of yogurt in hand and had to buy it somewhere - if you give me hints that it is possible.
As a reader, I want you to write the things I don't know about your characters, their world, and their story.
JRE
  • 3,245
  • 19
That's a great act of kindness, but why did he do it? Adding the "why" can make a large difference between "drudge" and "character building".
Clark noticed Jessie up ahead, the homeless guy he met last week, and decided to grab him some food again. So, he walked back to the store to buy a loaf of bread* and a yoghurt.
It's about the same length, but it gives it more flavor, like DWKraus mentioned. In this case, it's adding some history to the interaction. This goes from a one-off situation to something this Clark does at least semi-regularly, or is starting to do. This gives you the "interaction" you are seeking.
It also cuts out some of the specifics, but still lets the reader understand what's implied. Clark isn't a robot, so he doesn't need to be told exactly what to do, and neither does the reader need to learn about it.
You don't even have to get into the history of why, just saying a bit about the why is enough. Don't worry about Checkov's gun, there's plenty of reason to establish that Clark is a decent guy in and of itself that you don't need to mention Jessie again. I would warn against doing this too much, though. It can leave the readers wondering where all those random things mentioned were supposed to go, leaving them unsatisfied with the story arc that seemed to have a lot of unfulfilled branches.
* As a side note, in American English, we don't usually say "a bread", but "a loaf of bread" or "a couple slices of bread", which is why I changed that part.
computercarguy
  • 660
Skip[p]ing any of the actions may confuse reader as it would sound as hero conjured something out of nowhere.
The reader can probably guess where the groceries came from, but if you want to make it more explicit, discussing things that happened in the past for which the focus is how they relate to the current situation is what perfect tenses are for:
He gave some groceries that he had bought earlier to the homeless guy.
You don't need to describe him buying the groceries; you can use past perfect to present the purchase as something that has already taken place.
Acccumulation
  • 651
Without knowing more about the context and the impact you are trying to achieve, it is impossible to suggest how the paragraphed should be reworded. However, as a standalone piece of English, it is neither polished nor efficient.
Around is unnecessary- you could just say he turned (if you think it important to say he turned, otherwise omit both words).
Started is a word that's often used unnecessarily, as is the case here. You could just say he walked.
Is it the only nearby store? If not, say a nearby store.
You don't really need to say the store is nearby- if he walked here, the reader will assume it's in walking distance.
In British English 'a bread' is not standard usage. We would just say he bought bread, or a loaf etc. A yoghurt could just be yoghurt.
Then is another word that is often used when not needed. You don't need then to indicate that the words following it describe the next event in a sequence if the reader can plainly infer it.
The use of the word 'came' is interesting, as it places the narrative voice as having remained with the homeless guy.
Strictly you don't need to say he returned, as that is implied by his giving the groceries to the homeless guy.
You could convey the same meaning with half the words...
He walked to a store and brought back bread and yoghurt for the homeless guy.
The crux is not adding the action, but the decision, the choice. It’s those that define a character!
