17
I'm writing a novel with many POVs, and this is a very flexible story. It started out with a few POVs who had one plot, and now there is a lot more, having been integrated in between those previously existing POVs. But now I'm thinking about adding a new POV that brings a ton of implications. A vampire POV.
The reader will be acquainted with mystical and magical beings from chapter one, where a demon is present. So the problem is not that suddenly a magical element is added far into the story. The problem is that an entire, previously not mentioned species is added to the story. Now, the world is described as being home to many different types of beasts. But vampires aren't any type of beast, they are established within literature. So, will suddenly adding this species to the mix over twenty chapters in throw the reader off (in a bad way)?
Of course, I have no problem adding a mention of vampires in an earlier chapter. But I'd like to know if it'd be alright if I didn't. I want to know if all of a sudden adding a species far into the story is a good idea.
Cyn
  • 32,483
  • 77
  • 145
A. Kvåle
  • 4,073
  • 23
  • 52
9 Answers9
23
I think you can look to Harry Potter for inspiration to answer your question.
Every book introduced new species. Some at the beginning of the book, and others in the middle. But they were always introduced before they became important to the story.
In the first book, the dragon egg showed up with no real fanfare and became something that fleshed out Hagrid's character and added some comic moments, but later that dragon became very important to the story. Similarly, the hippogriff was introduced in book 3 and demonstrated differences between Malfoy Draco and Harry Potter, but later became very important to how the story unfolded.
So, if you think your story needs vampires to be even better, then add them. But, like HP, make sure it's clear they exist before they are important to the plot - or those moments in the direction of the story where the arc changes.
If you blurt out "oh there are vampires", then you may telegraph something about your story before you want it revealed. But if the vampires are introduced in a way that develops your characters more fully, or presents a challenge to the character that is already well established, so we are learning more about someone we are interested, then the vampires will be as accepted as HP's Grindylows and Nargles.
You can contrast this with Out of the Dark by David Weber. In the very last chapters, he introduces the story element that saves the day. It was in plain sight all along and it was foreshadowed as well, but it was done in a manner that caused me to dismiss it. So when I got to the point of the reveal, I felt cheated. I still read it twice because I like his work. But I was disappointed in the ending both times.
PoorYorick
  • 2,892
  • 15
  • 34
EDL
  • 13,380
  • 26
  • 62
22
Some of the best worldbuilding is done gradually.
If you introduce all the elements of your fantasy world very near the beginning, you risk boring your readers with a massive infodump. It's often better to introduce it piece by piece, as long as you do so in a way that seems 'natural'. This is why a lot of fantasy follows the standard Tolkien motif of the young provincial protagonist with little knowledge of the wider world - then the readers can learn about the world together with the character, and learning piece by piece is consistent with the story.
Example: in Robert Jordan's Wheel of Time series, there are a vast number of characters and cultures which we learn about throughout the series. No way could all of those be explained in the early chapters, or even in the first book. We don't even understand fully what Aes Sedai are until around book 2; Aiel culture is introduced around book 4; Seanchan culture even later than that.
How to make a new introduction to the lore 'fit' with the story?
I mentioned above that you should introduce new elements of your world in a way that seems 'natural'. What does that mean exactly?
As a minimum requirement, it should at least make sense that this wasn't seen before. Going back to the Young Provincial Protagonist trope, it makes perfect sense that the readers only learn about Xidajopian culture halfway through the book if the viewpoint characters were unaware or ignorant of Xidajopia until then. But if you introduce a new magical ability which some characters had and knew about all along, you'd better make sure it's something they had no cause to use before.
For extra bonus points, make the new introduction fit with something previously unexplained. Sometimes it feels to readers as if the author is making it up as they go along and hadn't even thought of some new piece of lore until the time it's introduced. The best way of proving that your new addition isn't ad hoc is to make sure it connects with something earlier in the story, but not in such a way that everyone could predict it from that earlier something.
Example (bad): another answer here mentioned J. K. Rowling's Harry Potter series, in which many creatures and types of magic appear only far into the story, so that the worldbuilding gets deeper as the series goes on. But sometimes a thing introduced in a later book makes a nonsense of previous books because "why wasn't it used back then?" (the out-of-universe reason being "the author hadn't invented it yet back then").
Example (good): in Brandon Sanderson's Mistborn trilogy, there's a very logical and well-defined magic system, but not all of it is revealed at once. The first book introduces us and the main character to Allomancy and Feruchemy, but Hemalurgy is only understood in the third book. When that happens, we realise that many minor things throughout the story are in fact connected with it. It's clear beyond a shadow of a doubt that the author did have this in mind from the beginning, but at the same time it would've been impossible for even the shrewdest reader to predict the details of this new magic system.
Rand al'Thor
  • 809
  • 26
If you've established your world as one with fantasy species, it's okay if you don't mention every one early on. Lots of novels and screenplays throw new species into the mix later on and that's fine, so long as you've established that your world is one where similar species already exist.
Novels such as A Discovery of Witches establish a couple species not long into the story but add others later, sometimes in other books in the trilogy. Well known species too. TV shows like Buffy the Vampire Slayer and Being Human do the same.
If you want to briefly mention or hint at it, that works too. But it's not necessary.
Cyn
  • 32,483
  • 77
  • 145
There's nothing inherently wrong with this at all - the important thing is that the introduction seem organic. Is there a reason why the existence of vampiric creatures wouldn't have come up (or even been known) to the existing POV characters before this point? If so, and it's in keeping with your world (you wouldn't just introduce actual magical wizards into Season 3 of ST:TNG for example!) then go for it!
Many stories with fantasy elements do similar, some by use of an audience surrogate (Harry in Harry Potter, Diana in the All Souls trilogy, etc) others because a complex supernatural world is big - and it can take time for even seasoned initiates to encounter everything (e.g. Harry in The Dresden Files).
Without wanting to cross much into world building here vampires are a an easy soft ball for this sort of thing - common tropes revolve around them living somewhat secretly from the rest of society (World of Darkness, Buffy, etc) and being relatively well equipped to do so.
motosubatsu
  • 7,282
  • 23
  • 46
This raises an alarm bell for me. The reason is that magical creatures aren't just scenery. They have a psychological and archetypal dimension --they carry certain thematic resonance along with them. If your book isn't built around vampire themes, and if they aren't foreshadowed, then introducing them late in the book might be a symptom of thematic incoherence.
As hinted at above, there are ways around this. If the story already has themes that are resonant with vampires --parasitism, creepy sexuality, blood --then the late introduction of an actual vampire may feel entirely right and appropriate. Or, if the existence of vampires is foreshadowed early, that could also work. But dumping a vampire in late with neither of these things in place smacks of either desperation or self-indulgence.
This last point is just personal prejudice, but for me as a reader, late introduction of a new first-person POV (vampire or not!) is something that would almost always cause me to abandon a book entirely. I dislike multiple first-person POV anyway, and when it is introduced late, it completely ruins my immersion. (You didn't specify first-person, so this may not apply).
Chris Sunami
  • 56,510
  • 87
  • 195
OP: So, will suddenly adding this species to the mix over twenty chapters in throw the reader off (in a bad way)?
It certainly can do that, but you might get away with it. One way is to spotlight the fact that you haven't previously mentioned them, if you can think of a reason nobody has mentioned them in the first twenty chapters. Perhaps some magical concealment, or vampires are just covert. Perhaps they have learned to conceal the fact that they are operating in an area, disguising their kills as something else: rape and murder or lethal mugging. No characteristic teeth marks on the victim's neck. Or perhaps they have acquired magical amulets that transform the punctures of their teeth marks into the appearance of run-of-the-mill strangulation, looking like a rape. Or after feeding, they can make the remains of their victims vanish.
You can even begin the chapter with the vampire telling somebody (say her date) all the reasons she never believed in vampires, all the ways vampires don't make sense.
Yet another solution: In the final scene of the previous chapter, the previous POV character by some magical means learns, conclusively, that vampires are real, maybe along with the reason nobody talks about them or knows they exist. Then boom the next chapter stars a vampire.
You cannot make the new species look like a deus ex machina just to get your main characters out of a jam or solve some other problem. If they struggle against a bad guy, and your solution is "There are vampires, the vampire kills the bad guy, problem solved", that is not satisfying.
In other words, the vampire should not simplify anything for your main characters, it should complicate things for them. And unless you are writing a farce, don't make the vampire just another cardboard villain for them to put a stake in.
If you introduce a vampire character out of the blue, it is best if the vampire has a new problem, and the vampire's attempts to solve their new problem causes more new problems for the Main Character (or Main Crew).
So three parts: First throw a spotlight on why nobody in the world ever talks about vampires, Second give the vampire a new problem (an inciting incident that puts them on a new path to intersect the MC), and third, make sure you have complicated the story, do not let this introduction solve any problems for the MC.
Later (as EDL noted in Harry Potter) the vampire may indeed be instrumental. Later, in solving some problem for the MC, perhaps they cooperate, or perhaps the help to the MC is a side effect of the vampire solving its own problem (i.e. that is how the vampire's arc is concluded).
But not immediately; in its first chapter the Vampire must contribute to the troubles of other POV characters, and should have a real and new problem of its own to overcome, some motivation for changing its routine. It would be great if you can tie the vampire's new problem back to something caused by the POV characters; then the Vamp coming out will look like an unintended consequence of the Main Crew's actions.
Amadeus
  • 107,252
  • 137
  • 352
If there is a problem in your story, the problem is earlier in your story.
You don't need to explain the element earlier, but you need something--anything--to get the reader prepared.
The way to know if your current execution is problematic is to ask a reader. If the answer is yes, find a way to tip off the reader some time earlier.
It's a skill that is not hard to pick up and it works.
SFWriter
  • 23,852
  • 48
  • 120
As other Answers mentioned, this can be done is a valid way for world building, however you can also make it a complete shock and turn it into a plot twist.
There are many bad ways to do this, but there are also many good ways to do it.
If you make it a shock to everyone all the time, then it's a bad plot twist. You will lose the readers ability to be surprised and will assume that you only wrote the book to try to insert as many "shock value" jumps as possible. While this might work for some horror genres, it doesn't necessarily work anywhere else. Also, too many plot twists can make the book hard to follow.
Making the shock a sustained but short surprise can work when introducing something. The initial shock being that something exists, then the sustaining medium being the explanation why it's "normal" to the people who know the secret.
There are plenty of stories like "Alice in Wonderland" and "Peter Pan" that start as a normal version of this universe, but end up in a fairy land of wonderment and fantasy. It wouldn't be too hard to take those stories and extend the beginning of them so the fantasy aspects are later in the novel.
For instance, Alice could have a long story of how she has imaginary friends, takes her real friends on imaginary adventures, and then halfway through the book finds out there actually is a magical realm where she has real adventures. The current story only hints at those early adventures, because it wants to get to the fantasy aspect.
The story could even extend afterward to Alice bringing her friends to Wonderland to prove that it's real, they have more adventures, and even continue through her adulthood. "Through the Looking Glass" was an example of how this could happen.
computercarguy
  • 660
If (as you say here) the vampires despide and hunted down, then it may be possible (if it does not conflict with other parts) introduce them out of blue in something like this (yeah everyone knows about vampires, there just was not reason to show it, until now):
... and so I stopped the running boy and asked him "what it is all about?"
"Don't you know? They catched a vampire today! They say that he will be put in chains on the main square for all day long and then burned at evening!" he enthusiasticly waved his hands as if he catched the vampire itself.
"Finally some good news" I replied "I did not heard about such catch for so many months!"
"Yes, our Prince is realy a hero" agreed the boy "nobody is such good vampire hunter as he is. Heralds say, its his tenth vampire and that the show will be really big today!"
"I must be there for sure, cannot miss such great event" I told, but the boy was already running toward main square again ...
gilhad
  • 250
