12
I have the habit of using paired adjectives in my writing:
  • The noise from the engine lulled her with its slow and monotonous rythim ...
  • ... the lights on the ceiling filled the room in a soft and warm hue ...
  • ... his skin was smooth and thin, like paper ...
The examples may be not 100% accurate since I don't usually write in english, but let's pretend.
Now, sometimes even single adjectives are frowned upon (What's with all the hate on adjectives and adverbs?) - so by logic paired adjectives shouldn't be any better. I remember reading reviews criticizing this very aspect in published novels, but I never understood if there are solid reasons to back up this opinion.
So, are paired adjectives bad style - and if so, why?
Addendum: I'm specifically asking about novels and fiction.
Related question, in technical-writing:
Liquid
  • 15,895
  • 52
  • 117
6 Answers6
19
The double adjectives might be creating a sentence rhythm that feels strong while you write because it seems to "double bounce" in a smooth way – in this case it's not a fast bounce that picks up speed, it is a slow bounce that causes the pace of reading to become deliberate, like when you take a deep breath and let it out. "One and two…, ahhhh"
I'm going to start a writing war and say ADJECTIVES ARE GOOD (in general), but what might be catching your critical eye is that you notice it keeps happening, and maybe the 2 adjectives are not really as strong as a well-chosen single word, or maybe the double-bounce slow pace doesn't match the tone you are trying to achieve for the scene.
It's ok, that's what re-writing is for. If the double adjective helps you get through the first draft, and you change it on the re-write, that's a normal part of writing. The first draft will end up having these language rhythms and figures of speech that come out of habit and familiarity. Now that you have recognized your pattern, you can decide how to deal with it.
It works in the context of slowing down, of slow breathing, of a character reassuring herself that everything is fine. Obviously you will want to break that pattern or avoid it when everything is not fine. You could even attach the quirk to one character who speaks in these rhythmic patterns as a way to hypnotize or reassure, and then later when you break the pattern we know they are not ok.
wetcircuit
  • 29,603
  • 51
  • 129
As a reader, I think that adjectives are helpful in making a better image of what the writer is trying to say. But repeating adjectives that have almost the same or similar meaning (e.g. slow and monotonous, soft and warm, thin and frail) would be considered a bad style, as it would be counted as irrelevant explanation and waste of words, and would definitely bore the reader.
But pairing adjectives like smooth and thin, etc is fine as they both describe completely different properties of the paper and one of them can not replace the other.
Bella Swan
  • 587
Stately, plump Buck Mulligan ...
This is one of the more famous opening lines, from one of the most renowned masters of the form.
Ulysses If Joyce can use these two paired adjectives to begin setting the scene so well, this @Liquid is surely an example of a pluterperfectly recommendable style.
MikeRoger
  • 190
As in so many instances with English, it all depends.
The practice is most often abused by overuse. If all of your adjectives are double, this will be noticeable, and this can be either good or bad.
Most English speakers don't use double adjectives most of the time. If you do use exclusively (or even predominantly) double adjectives, this will ordinarily be seen as peculiar and distracting.
You can use this, however, if a particular character always does it, and it will establish the character as distinct. Probably a bit annoying or weird, but distinct.
TL;DR - You can do it in moderation. Grammatically it's correct, but stylistically it's dangerous, particularly if you do it a lot. Unless you make it work for you. As a writer who does not normally write in English, don't push your luck. Moderation in all things.
WhatRoughBeast
  • 581
I think I might choose a comma, rather than a conjunction, in such a case, e.g.: "The slow, monotonous rhythm" but I don't think it's actually wrong to use a conjunction.
I would strive for variety in your writing, so the fact that you've already noticed a pattern means you need to be careful. Overuse of that single technique - even if you choose the perfect pair every time - will turn you into a one-trick pony.
I like where @wetcircuit was going with their answer, but want to expound just a little more.
Number of words used to describe something:
3 words: Good rhythm. Readers love groups of three.
She was the queen's daughter, no doubt: dark, beautiful, deadly.
2 words: Good at elaborating or showing contrast.
Her bright, fancy dress hid a cold and sinister heart.
1 word: Sometimes gives the most impact.
The grin on her face could only mean one thing. Trouble.
Choose the right number of adjectives for your sentence, recognizing that these are flexible and will depend on context and how recently you used that same technique.
icanfathom
  • 791
  • 14
