31
The tall figure was overwhelmingly tall. It stood in the corner of the room. The skinny figure right beside him sat on a chair. It wasn't moving at all. The tall figure moved to the opposite side of the room and started palpating the wall as if it was looking for something. The skinny figure then started crawling and palpating the floor as if it were looking something. The tall figure then started laughing loudly and clapping his hands as if it were overjoyed. The skinny figure hearing this started doing the same.
How do I minimize the amount of repetition? Is there a way of doing this without changing drastically the sentences? What would you suggest? As you can see, I used "it" immediately after using the adjective-noun pairs but, when I switch person, I have no choice but to use the appropriate adjective-noun pair.
Cyn
  • 32,483
  • 77
  • 145
5 Answers5
41
You have a few choices here:
1. You can group each person's actions together more (I've also edited a couple errors).
The tall figure was overwhelmingly tall. It stood in the corner of the room then moved to the opposite side of the room and started palpating the wall, as if it was looking for something. Then it started laughing loudly and clapping its hands as if it were overjoyed.
The skinny figure sat right beside the tall one on a chair. It wasn't moving at all. It then started crawling and palpating the floor as if it were looking for something. When the tall figure was laughing and clapping the skinny figure started doing the same.
2. You can name the characters. If you don't want to use real names, try the characteristics.
Tall was overwhelmingly tall. It stood in the corner of the room. Skinny right beside it sat on a chair. It wasn't moving at all. Tall moved to the opposite side of the room and started palpating the wall as if it was looking for something. Skinny then started crawling and palpating the floor as if it were looking for something. Tall then started laughing loudly and clapping its hands as if it were overjoyed. Skinny hearing this started doing the same.
3. You can make them different genders. Instead of making them both "it" (with some accidental? "he" in there), make one "he" and one "she."
The tall figure was overwhelmingly tall. He stood in the corner of the room. The skinny figure right beside him sat on a chair. She wasn't moving at all. He moved to the opposite side of the room and started palpating the wall as if he was looking for something. She then started crawling and palpating the floor as if she were looking for something. He then started laughing loudly and clapping his hands as if he were overjoyed. Hearing this, she started doing the same.
Cyn
  • 32,483
  • 77
  • 145
24
You can look for other ways to identify the characters. For example:
The tall figure stood in the corner, towering over the unmoving skinny figure in the chair beside it. It moved away from the seated figure to the opposite side of the room and began palpating the wall as if looking for something. The other figure crawled from the chair and began palpating the floor. (etc)
In this example, "towering over" avoids repeating that the tall figure was very tall, "unmoving" avoids saying that the skinny figure wasn't moving, and once you know the identity of one you can refer to the "other". The riskiest thing in my version, clarity-wise, is who moved away, because the "it" could be ambiguous. That's why I said it moved away from the seated figure; that tells you who's acting by process of elimination.
I've stuck with your sparse description here, but if you had described the figures more, you could make use of that too -- referring to someone's lanky legs, blond locks, frayed cloak, or whatever.
You can identify characters in ways other than the noun phrases you used to introduce them.
Monica Cellio
  • 21,489
  • 68
  • 110
10
I think you can achieve a lot by just replacing the “was” sentence by making it an attribute in the following sentence, and making use of terms like “the first”, “the former” and “the other”.
The overwhelmingly tall figure stood in the corner of the room. The skinny figure right beside him sat on a chair. It wasn't moving at all. The first figure moved to the opposite side of the room and started palpating the wall as if it was looking for something. The other one then started crawling and palpating the floor as if it were looking something. The former then started laughing loudly and clapping his hands as if it were overjoyed. The skinny figure hearing this started doing the same.
Note that I refrained from making any other changes to the text, so the impact of my suggestion can be seen in isolation.
celtschk
  • 4,027
  • 19
  • 29
How about something like this:
An overwhelmingly tall figure stood in the corner of the room. Beside him, a skinny figure sat motionless on a chair. Suddenly, the tall figure moved to the opposite side of the room and started palpating the wall, the other then started crawling and palpating the floor, both acting as if looking for something. The tall figure then started laughing loudly and clapping his hands as if he were overjoyed. His companion, on hearing this, started doing the same.
Notes:
I didn't like the "tall figure was tall" construction in the first sentence, so lost one of the talls. The description of the skinny figure is also compressed.
I've used an adverb to emphasise a break between the initial description of the two figures and when they start moving. "Suddenly" might not be the right choice for what you have in mind.
I really didn't like "one did this as if looking for something, then the other did that as if looking for something." Way too repetitive. So I pull the "looking for something" bit into a separate sentence.
Although I've left it in my version, I'm not crazy about using "palpating" (especially twice!). It's a very technical term which doesn't properly apply to walls or floors. I'd consider looking for two suitable synonyms: "One started searching the wall, then the other started examining the floor." If you must, leave one figure palpating but choose a different verb for the other. I think, if you pick two more suitable verbs, you might not need to add the "as if looking for something" bit at all.
Is the tall figure a "him" or an "it"? You use both pronouns in your short passage: "The skinny figure right beside him sat on a chair. [...] The tall figure then started laughing loudly and clapping his hands as if it were overjoyed!" I've gone with "him" in my version.
I swapped "the skinny figure" for "his companion" in the final sentence to reduce the repetition. The only repeated phrases left are three "tall figure"s (which I think is OK), and two "palpating"s (which I don't like - see above).
Chris Hunt
  • 216
This is an easy problem.
After a brief description of the unnamed Tall Figure, you can simply refer to it as "Tall" henceforth.
Similarly the skinny figure can be referred to as Thin
And then until you reveal their name, you can simply refer to them as Tall and Thin
ashleylee
  • 1,162
