27
In today's frenetic, fast-paced lifestyle (especially if writing is not currently your career or means of earning an income), it can be extremely difficult to "make" or find the time that can be set aside and dedicated to writing. Not only that, but in this information age, there are so many distractions ready to destroy what focus there is.
Obviously this hinges on motivation and drive, but nonetheless I have to ask: what means and methods do others use to foster and maintain discipline around their writing?
Zayne S Halsall
  • 2,173
  • 19
  • 35
6 Answers6
22
I rely on two tactics to achieve steady progress in writing (I'll answer twice for voting ease).
The first is sort of obvious - write every day. I fell into a trap at one time where I felt that if I couldn't block off at least a few hours for writing that it was better to not bother. As a result, I would sometimes go for weeks without writing (that doesn't make editors too happy).
Eventually, I forced myself to write every day - even if I knew I could only write for 15-30 minutes (which almost always expanded into longer chunks of time). Now, when I have writing projects, I make sure I write every day - even if it's just edits or a sentence or two. For me, a lot of writing happens somewhere in the back of my mind when I'm away from a keyboard, and writing every day keeps those ideas moving.
Alan
  • 1,483
  • 14
  • 13
15
Quite simply: Block off the Internet as you write. For me, that involves turning off my secondary monitor so I can't see the taskbar. For you, it might involve physically unplugging the ethernet cable from the back of your computer.
I can't even begin to describe the difference this makes for me when I write.
StrixVaria
  • 5,983
  • 42
  • 44
11
The second thing that has helped me is the 10x5x2 approach (it may have another name). The theory is that you write for 10 minutes, take 2 mintues off, then repeat 5 times (filling an hour). The idea is that the schedule will make you focus, but give you time to deal with necessary distractions if necessary - often I use the two minutes to stare at the ceiling and think. I wrote a little timer application to help me and use it every time I write now.
At the end of an hour (if I'm going to write more), I'll take a bio-break or get some coffee. I found that I can string up to 3 of these back to back before I need a longer break, but that I can do up to 6 in a day if I'm really pushing.
Alan
  • 1,483
  • 14
  • 13
Blocking out distractions is the key to doing anything productive. In the case of writing you need to put yourself in a situation where all you can do is write. There are two methods I like to employ, one digital and the other analogue. On my computer I use an application called PyRoom which places a black fullscreen interface over my entire monitor with only a green box in the middle where I type. There is no option to use it in windowed mode, so you can't see notifications happening in the background. PyRoom is a Linux only application, but the paradigm of blacking out the rest of the screen is one that many application developers build upon.
The other method is to take a notepad somewhere and sit down to write. A good place to go is a coffee shop, or a park, or perhaps even oscillate between both. Being away from your computer like this with a non-interactive medium such as paper is a great way to get yourself focused on the task at hand.
In both cases, some lyricless music is also good. It stops your mind from picking up on every little noise that is happening around you. The human mind has a really annoying habit of filling silence with it's own noise when it's not tired, and silencing that noise with music works really well.
Basically, hide your distractions.
My most available writing time is between "waking up" and "leaving for work", that usually gives me between 30 and 60 minutes each day, usually good for 300-400 words (and a quick read of the last two days worth of writing). However, I suspect that is not a scalable method.
Vatine
  • 1,185
  • 18
Moving to a location that your mind doesn't associate with leisure is a good method to focusing it on the task at hand. I find it impossible to work at home because it has lot of leisurely baggage hanging around it's neck. I host parties, movie nights, read, play computer games, etc, and this is what my mind, when at home, gears itself up for doing these things. Head out to a library, or an office if you have one, and sit down and do some writing there, or to a coffee shop, or just anywhere at which you don't usually pursue leisurely activities.
Even just setting up a dedicated office in your home can be enough for some people. Closing the door behind them and shutting out the bedroom and living room is enough for many work-at-home writers to get themselves focused.
