34
I am plotting out a longish story, which would have the following number of characters:
Main/ reasonably significant characters: Nine
Characters still vital for the story to work:Thirteen
Side characters, named, with a little detail because they are colleagues/relatives of the character whose POV is in use: Nineteen
Is this too many? Only the Nine+Thirteen characters are fully developed, but I'm concerned that upon reading the names of other characters a reader might get bogged down, especially if I give them the odd detail. I'm trying to create a lifelike situation where we generally all have multiple people on our peripheries.
Jilli
  • 343
11 Answers11
51
As a reader, I very much dislike large casts of characters, I lose patience and the ability to tell them apart quite quickly. However, a lot of it depends on how they are deployed. If your main character travels a lot, for instance, he or she might naturally encounter quite a lot of different people, who, however, would only appear a few at a time, and thus be easily distinguishable.
In general, the rule I would recommend is this: If they are easy to tell apart and memorable, keep them in. If they are easily confused with each other, combine them. If they are forgettable, drop them.
The biggest red flag in your question for me is "trying to create a lifelike situation." Fiction can simulate and imitate life, but it is never truly lifelike, and we'd lose patience with it if it were. It's a little slice of life at best, and we rely on the writer to drop the boring stuff, and highlight the parts that are of greatest interest.
Chris Sunami
  • 56,510
  • 87
  • 195
36
Unless you are writing a screenplay or stage drama the specific number of primary and secondary characters (ie: speaking roles) doesn't matter. There are no budgetary concerns from too many characters.
If you say the characters are necessary then they are necessary. Otherwise you must change your story, skip scenes, or combine characters. If these characters serve a logical role in their scenes, and the scenes are logical in progression, the readers won't be confused by their presence.
Just so long as they are not all in the same scene at once while the reader needs to recall specifics about their backstories by name, you should be fine.
wetcircuit
  • 29,603
  • 51
  • 129
16
Consider, for example, The Lord of the Rings: you've got the Fellowship (nine characters), you've got Bilbo, Elrond, Galadriel, Theoden, Eomer, Eowyn, Denethor, Faramir, Sauron, Saruman, and several more all vital for the story to work, you've got a lot more named side characters.
There are other examples. Song of Ice and Fire, for instance. So in terms of sheer numbers, you're fine.
However, your concern is not unwarranted: with so many characters, you do need to take steps so your readers don't start mixing them all up.
How do you do that? First, character's names need to be sufficiently different. Readers often complain about Sauron and Saruman being two bad guys with confusingly similar names.
Second, don't dump all the characters at once on the reader. Introduce them a few at a time, let the reader get to know each - who they are, what's their relation to the MC / the plot.
Galastel supports GoFundMonica
  • 58,107
  • 176
  • 303
12
The number of characters in a novel is probably not a number you can fix. The number of characters in a scene, and in an arc, however, can be significant.
Essentially, each character in a scene should create tension in the scene or arc, should shape the way the scene or arc unfolds. The basic test here is, how would this scene be different is this character were not present? There is obviously no fixed number for this, but there is also obviously a point where adding one more character is not going to add tension to the scene. Even if that new character is in tension, their presence is almost certainly going to take other characters out of tension. Any character that is not adding tension to the scene is adding distraction and should be removed.
The other thing to remember here is that character does not equal person. From the beginning of drama, we have had the concept of the chorus. The chorus may be many person strong, but they speak with one voice. If they add tension to the scene, they do so as a unit. For dramatic purposes, therefore, the chorus is a single character. This does not mean that they could be replaced by a single person; it means that the mob, the people, society, acting in unison act differently from the way individuals act, and thus the chorus becomes a different kind of character, one that acts in a different way and thus creates tension in a different way. The dwarves in the Hobbit are a good example of the chorus.
So the question you should be asking is not what is the right number, but rather, is each of my characters in tension in the majority of scenes that they appear in. If not, they are superfluous and are weighing the story down. Keeping a large number of characters in tension is obviously much more difficult than keeping on a few in tension, but this suggests that the upper limit is determined more by your skill as a writer than by any limit on the reader's tolerance.
Chris Sunami
  • 56,510
  • 87
  • 195
11
As other answers have suggested a large character count is ok, if you manage them correctly.
Building on the Tolkien idea in Galastel's answer I want to add that The Silmarillion has an unbelievable character count (well more than 100 according to the Wiki) that has indeed driven away some people while at the same time being a successful book. According to the reviews on Amazon readers do have problems with that kind of number, but many found a good glossary, family trees, maps or eBook technologies to be immensely helpful (see for example [1, 3rd paragraph], [2, section c.], [3], [4], [5], [6], ...).
What one can take away from this example is that you can help the reader. You can do something like the appendix as in the Silmarillion example but I don't think that's all. Here are some brainstorming ideas (including some of the above):
  • Glossaries.
  • Family Trees. Or other graphical representations of relationships.
  • Maps. Where are characters moving? If regions are controlled by anyone of significance, put that on the map. You could connect characters who don't have too move much with landmarks.
  • Mind the scope. It's hard to remember some character including related facts when it hasn't been mentioned for 500 pages at all. It doesn't hurt to offer a sentence with a small hint what kind of character you are talking about or what that character did when it was first mentioned. Maybe it's not only the reader who might have trouble remembering or is caught off guard, but also the character itself that is meeting another character? It seems to me that this would fit quite well with your "lifelike situation" approach.
  • Names. See Galastel's answer. (Exceptions apply. Naming "double characters" similarly or using the same naming scheme for characters from the same family or region or culture makes sense and actually helps with putting them in the right place.)
In summary: With enough help and thought, almost any character count works.
Liath
  • 1,900
  • 23
  • 29
Piwi
  • 211
It depends a lot on how the characters are introduced and managed. As long as the reader can keep track of which character is which, then it should be okay. But keep in mind that readers will not be as familiar with the characters as you the author are, so make sure that you are compensating for this.
Basically, the more effectively you manage your characters, the more characters you can introduce without confusing the reader. TV Tropes has a nice list of tips for effectively managing a large cast of characters. See also Loads and Loads of Characters. In summary:
  1. "Cast of Snowflakes": Make the characters look distinct. This is tip is more for the visual medium than the written medium, but it's still nice to keep in mind.
  2. "One Steve Limit": Try to avoid giving characters the same or even similar-sounding names.
  3. Give characters unique quirks, hobbies, and twitches: It usually takes me a while to learn names. Giving characters unique traits makes it easier to remember which character is which, even if I don't remember their names.
  4. Group characters into "Cast Herds": In general, grouping related things is helpful for memorization.
  5. Give your reader clues as to whose POV/scene this is: Redundancy is good!
  6. If you have a large cast list, include the list in your work.
  7. If all else fails, feel free to hang a lampshade.
Another key point that I would like to add: I think it's very important to avoid infodumping all of the names on the reader all at once. They won't retain any of it. Instead, it's a good idea to introduce names gradually and carefully. And make sure to give the readers multiple chances to learn the names.
Typically, when someone gets to know another, it usually takes them a while to remember the new name. Usually they would remember them using some distinctive trait such as "spikey hair" or "glasses guy". Only a while after that would they retain the first name. And only a long time after that would they retain the family name. If at all. Of course, if the relationship is more formal, such as student-teacher, it would typically be the other way around: They'd learn the family name first, and then only much later learn the given name.
In any case, when using new characters, keep in mind that the readers will be most likely remembering them using only distinctive traits for the first little while.
ahiijny
  • 259
I'm going to point out that the named casts in Peter F Hamilton's works often top the 30 character mark. Having said that those works are huge, don't commit to more characterisation work than you can actually accomplish, if you can't actually flesh out characters enough for them to do their job, without overwhelming the story, there's not a lot of point having them filling the roster. This is an issue not only of writing material for the characters but also of fitting that material into the story without the whole piece turning into a series of character introductions between minor incidents that don't feel fleshed out because of their relatively small size compared to the mass of character detail.
In summary depending how long your piece is balancing that many characters might be awkward but there's no hard-and-fast rule as to how many, or few, characters work in a piece.
Ash
  • 10,541
  • 58
It depends
If you're writing a short story, then nine is too many main characters. Nine is possibly too many characters period, depending on the length of the story.
The number of main characters in your story increases the complexity of the story exponentially, as you have to deal with all of the characters and all of their interactions with each other. The more main characters you have, the harder it is to balance them in an engaging story.
Try to identify the problems you've seen in other large cast stories
There are many excellent stories featuring large casts, but none of them are perfect. Figure out what they do that works well, and what they do that works poorly.
I also recommend the episode of the Writing Excuses Podcast on writing Ensemble stories. It's only half an hour long, but there are lots of good thoughts in it about how to make a large cast work.
Arcanist Lupus
  • 11,474
  • 22
  • 46
This isn't unreasonable. To give you an idea of a long cast list in a novel, take a look at the Harry Potter series. There are a ton of characters of various import to the narrative. Jim Dale, who recorded the U.S. audio books of the series, holds the Guinness Book Record for most voiced characters in a single audio book (134 in Harry Potter and the Order of the Phoenix) and then proceed to break his own record when he recorded 146 voices for Harry Potter and the Deathly Hallows.
Now, not all characters are equal, and Jim did record unique voices for such characters as The Ticket Taking Witch at the Quidditch World Cup... and that's literally everything we know about her. There is also probably the narrator voice, who was very close but still distinct from Harry Potter's speaking voice.
Wikipedia states that their are 8 main characters in Harry Potter (each getting a dedicated page). Supporting characters include Ginny (dedicated page) plus four additional pages classifying supporting characters by their associations (Hogwarts Staff, Order of the Phoenix Members, Dumbledore's Army members, and Death Eaters members).
hszmv
  • 13,474
  • 30
Many highly-popular shounen manga have dozens of characters, and it seems to work well. Examples are Dragon Ball, Slam Dunk, One Piece. Characters are introduced one by one. Some are developed slowly, some get a background story, most (except MCs) disappear after a while, to leave "screen time" to other characters. But then reappear later, and some keep appearing.
Update: Seeing @ahiijny's answer's point about names, one thing I think is different in manga (and Japanese works in general) is that names are used much more than in English, and this works well for reminding the reader/watcher. [I attribute this more to the Japanese language than to technique/device. E.g. in Japanese "what do you think?" would (roughly) be "what does X-san think?"]
Pablo H
  • 181
I have 109 characters among and through my 4 books. They all appear in one book at some point but They have different stories in different decades to shine and at same time i give them different chapters to shine on their own. Every now and then I combine past stories with the present characters. But I never loose focus on my top and most important 5 to 8 characters. They are the culmination of years and they receive all the preview back stories. 109, from the most insignificant girl or dude until the most important ones, in a very detail excel file I keep track of ages. That way I know in what time they should be at their best moment to shine without causing conflict between the older and the younger.
