For some reason, I can only seem to get in the "zone" at night time. Like 9:30pm and past that. Whenever I try to write during the day, I can't get myself to write something that's actually good, or even be able to stay focused.
Since I only write at night, I'm also often fighting to stay awake, and I make many grammatical mistakes that I have to fix in the morning. But there's also a plus for writing at night, my ADHD meds are more worn off, and I can imagine better ideas.
So, is it a bad habit? Should I try to somehow quit doing it? Importantly, how might this affect my writing?
Goodbye Stack Exchange
  • 9,426
  • 34
  • 76
AmazingMc
  • 111
You found a time when you can write. Why on earth would you want to break that habit?
Fix your grammatical errors in the morning. Get your ideas on paper when the Muse wants you.
Lauren-Clear-Monica-Ipsum
  • 75,160
  • 124
  • 264
If writing is all you want to do with your life, then what you do is fine.
If, on the other hand, you need to study, go to school, or perform a job, then your night time writing may cause you to be tired or otherwise dysfunctional in relation to your duties.
It may also be detrimental to your social life.
If you are awake during the night, you will need to sleep during the day. That is not healthy. You miss a lot of sun light (which your body needs to create certain chemicals), and you disrupt your body's normal diurnal cycle. The body heals and grows during night sleep. To name just one example, working at night increases your ADHD symptoms.
