So most scientific papers are written with multiple voices. In the introduction the problem is discussed and the writing will refer to "This Study" or "This experiment" if it must refer to narrative person.
The second part describes the steps taken to get the results which will be discussed further in the paper. As this section is written as a set of instructions, the second person imperative voice is used, often with an implied "you" as the subject of the sentance (you do not write "you" but skip the subject and write the imperative verb.).
The next section is the results which is written in the form of a third person objective voice. In Third Person Objective, the writer should describe only the information that can be observed with the sense. This is often refered to as "Third Person Roving Camera" as most audio-visual media rely on Third Person Objective.
Finally, the conclusion should return to the same voice as the introduction. The conclusion should refer to the conclusion of the experiment and rely soley on the results as the basis of any statements made. The narrator should not speculate but merely states that the result sets do not support a conclusion to any questions or that the question asked is outside of the scope of the experiment or study.
