I need to create two versions of a document, one in future tense and one in past tense:
Document A: The consultant will do X.
Document B: The consultant did X.
In the past, I've handled this by writing document A, then editing a copy into document B. This creates problems when making major changes; I can try to modify both documents simultaneously, or I can just edit document A and recreate B.
Neither of those approaches seem very efficient. Are there any well-established processes or patterns to handle this challenge? Is there a term to describe this scenario? Just knowing the right terminology would help me in researching this.
SArcher
  • 121
With some tools, you can tag the two verb forms as conditional text in the source document and then render the version you want in the output.
If you're writing a status report, I recommend using verb forms that let you sidestep revising/conditionalizing text, as shown here.
Example A
  • Consultant writes blog post. Completed.
  • Client publishes blog post. In progress.
Example B
  • Consultant: Write blog post. Completed.
  • Client: Publish blog post. In progress.
rolfedh
  • 1,935
  • 28
