I'm writing a guide to give step-by-step instructions to complete some tasks on the computer. At some points, I need to indicate pressing keys on the keyboard; how may I format the letter/symbol to best indicate them as keys?
I am assuming that your organization does not have an official style guide, or that this is a personal project. (If you are bound by a style guide, consult it.) I am also assuming that you aren't using a semantic markup already; if you're using a DTD/schema/tool/markdown that already has a notion of "keyboard input", you'd use that unless there's a good reason not to.
The Microsoft Style Guide is a common choice for software companies in my experience. This guide (4th edition, p 91) calls for capitalizing key names but not otherwise formatting them. It gives a list of "official" names of special keys. Keys that are used together are joined with '+'. Correct example according to this guide: Ctrl+Shift+?.
Some companies add bold face to this, e.g. Ctrl+Shift+?. In my experience this is especially common if the documentation also refers to UI elements like menu names. I think the reasoning is that "user-entered stuff" should look the same whether it's Ctrl+Z or File->Open.
I have sometimes seen a hyphen used in place of '+': Ctrl-Z, for example. I don't know the origin of this style.
I recommend against using a fixed-width font. In technical writing this style is usually reserved for console output, code, code elements like function names, and sometimes environment variables -- things you would expect to see in a terminal window, error log, or editor window, in other words.
- 21,489
- 3
- 68
- 110
