If yes does this apply to historical deities/gods or only to fictional ones?
    There's a situation that arose around the distinction between historical myths and modern fictional gods and dieties: https://www.acaeum.com/ddindexes/setpages/deities.html – Todd Wilcox Feb 20 '23 at 19:05
    Where exactly do you draw the line between a ‘historical’ deity and a ‘fictional’ one? Is Flying Spaghetti Monster historical or fictional? How about the demigod Wonder Woman? – Janus Bahs Jacquet Feb 21 '23 at 02:32
  • There's a character on the "Ghosts" TV show named Thorfinn, frequently called "Thor" for short. While I doubt it was required, I wonder if they sought permission from Disney to avoid trouble. – Barmar Feb 21 '23 at 16:27
  • I wonder whether Exodus 20:7 (Thou shalt not take the name of the LORD thy God in vain; for the LORD will not hold him guiltless that taketh his name in vain) was an early attempt to trademark the name of a Deity. – Simon Crase Feb 21 '23 at 17:22
  • Disney won't take issue with you borrowing their IP until their attorneys notice. If Varian were still around he'd probably sit you down and explain that the disney empire a whole lot bigger than Stormwind and it's best to let sleeping dragons lie. – Jacksonkr Feb 21 '23 at 22:40
  • This is most likely the same as the copyright or trademark laws of any other name or character. – NotThatGuy Feb 22 '23 at 11:24
  • @SimonCrase No, that's a reminder of Copyright. So subject to the jurisdiction that depends on the date of death of the author, and on whether the author's claimed omnipresence is overridden by any statutory maximum term. – Mark Morgan Lloyd Feb 22 '23 at 20:10
5 Answers5
15
I believe most ancient gods and goddesses fall under the public domain.
Myths don't have a strict "canon" to them most of the time. They're stories passed down through the ages, and everyone has their own interpretations. For example, the Greeks had their gods, and then the Romans renamed all those gods. Zeus became Jupiter. Hera became Juno.
Should the Greeks sue Rome over copyright infringement?
In the modern day, the Percy Jackson series is probably the first I think of for using mythology. Has anyone sued Rick Riordan for using the name of Zeus?
After all, Disney made the Hercules movie. Wouldn't a major corporation like that love to sue someone for using their characters? I don't see them copyrighting every mention of the Greek gods in media. Why? They don't own the Greek gods. You can't own mythology unless you make it yourself.
However, if I decided to use Hades in my story and made him a man with fiery blue hair, then I might have a problem with Disney. You can't use someone else's interpretation of a god. You have to make your own.
You also can't steal a god in someone else's canon unless it's in the public domain. Eru Iluvatar is a fictional god, yes, but he's in Tolkien's mythos, so you can't use him.
Nyctophobia457
  • 3,167
  • 22
    I note it would be trademark, not copyright, for the name, because it's too short to be copyrighted. – Mary Feb 20 '23 at 03:19
  • @Mary: It depends. If you have a character named "Harry Potter," then you will definitely have a trademark problem, but I strongly suspect that JK Rowling's lawyers will look very long and hard at whether you've copied any other elements of the character, and if so, try to make a case for copyright infringement on top of that. – Kevin Feb 20 '23 at 18:15
    @Kevin I love the character Harry James Potter-Evans-Verres! – Michael Feb 20 '23 at 22:48
    It's a common misconception, but the Romans didn't copy the Greek gods and change the names. They had their own religion and identified similar gods with each other. It happened with a lot of other deities from other religions too (Odin/Mercury, Isis/Demeter...), just very thoroughly with the Roman and Greek cases – Nolimon Feb 21 '23 at 00:44
  • @Mary Characters can be copyrighted. There are some requirements of course, but using the name of someone else's major character would be a very bad idea. Also note objects can be considered characters as well. – AmiralPatate Feb 21 '23 at 15:32
    @AmiralPatate Characters can be copyrighted, but characters' names generally cannot be because there is insufficient creativity in an ordinary name. If a character appears in multiple works such that their name becomes an indicia of origin, then it can be registered as a trademark. – A. R. Feb 21 '23 at 17:11
  • This seems like only half the answer. It answers for Aesir, but not for the Elrich Universe gods. – T.E.D. Feb 21 '23 at 17:19
  • the Greco-Roman deities are not a case of plagiarism. It's sincretism. It is the same phenomena happening in Brazilian Candombé, where the Orixás are an amalgam of Afircan deities and Catholic figures. Though in the latter, at lest, it was done by slaves to hide from persecution. – Mindwin Remember Monica Feb 22 '23 at 18:02
  • @Mary What's the minimum length for copyright? – End Anti-Semitic Hate Aug 14 '23 at 03:48
  • @RockPaperLz-MaskitorCasket You should break that out into a question. – Mary Aug 14 '23 at 12:11
  • @MindwinRememberMonica It's actually in a lot of voodoo and similar religions (Hatian Voodoo is probably the best known) it should be pointed out that West African Dispora Religions' Loa (for want of a better term) and Catholic Saints are syncretism because in both faiths the figures are explicitly not deities. In fact, most religions of this type are Monotheistic with the Loa being spirits who can talk to the one God. In Catholicism a saint is a person who is confirmed to be in heaven, and are not deities. – hszmv Aug 14 '23 at 17:36
  • @hszmv The Ubanda Orixas are considered deities. Scope matters, and I was not talking about all Afican-Matrix religions. Only the Brazilian one, which only disguises itself as monotheistic. Beware the generalization fallacy. – Mindwin Remember Monica Aug 15 '23 at 14:06
In order to have a copyright, you generally have to actually have created the work in the first place or else hired someone to do so. If you write a story about ancient Greek gods, then you own the copyright to that story (unless you wrote it for hire under contract or employment, in which case copyright ownership can vary somewhat by jurisdiction as well as contract terms, but usually belongs to the entity that hired you.)
If you make up your own gods, then you may also be able to trademark them.
In the case of historical deities, no one owns either a copyright or a trademark for the deity itself and generally copyrights on original writings about them (e.g. original biblical text, Greek or Roman writings about their gods, the Quran, etc.) would have long since expired if they had ever existed in the first place. However, if someone writes a new work about such a deity, the author would generally own copyright to that new work. But they do not own any sort of intellectual property rights with regard to the deity itself. That is, someone else could write a different story about the same deity without any legal problem. They just couldn't copy part or all of the other author's original work without permission.
reirab
  • 320
If they were created for a copyrighted fictional work, then yes, those gods and their names are definitely copyright protected.
This actually happened with the first printing of TSR's D&D reference book Deities and Demigods which contained gods from over a dozen different mythos, three of which were protected by copyright (at the time): Fritz Leiber's "Nehwon mythos", Michael Moorcock's "Melnibonéan mythos", and H. P. Lovecraft's "Cthulhu Mythos".
Although TSR obtained permission for these, prior licensing agreements required them to credit a competitor, Chaosium Games for the latter two of them. Because of this, TSR dropped those from later printings. Because of this, those rare first editions later became quite valuable (I happened to have bought one when it was first released).
Further, TSR later sued another company (Game Designers' Workshop) claiming that they had based one of their mythos on the Shadow Plane mythos in Deities and Demigods.
Note however, that copyrighted material can be used in the U.S. as long as it falls under the limits of "Fair Use", which for practical purposes here would mean non-fictional reference and review-type articles. Using them in your own fiction would usually only be passable in parody and satire (unless you got permission first).
RBarryYoung
  • 141
    +1. A more interesting thing to explore would be the copyright status of Marvel's Thor. – T.E.D. Feb 21 '23 at 17:21
  • @T.E.D. Agreed that's definitely a complicated one. I'm no expert on that matter, but clearly the name itself cannot be copyrighted, so it would have to be based on appearance (which is quite different from the traditional Norse mythos portrayal) and other specific novel deviations from the mythical Thor (which is obviously in the public domain). – RBarryYoung Feb 22 '23 at 14:43
It is possible to get a deity's name recognized as a trademark. For instance, the goddess Nike is registered as a trademark.
For copyright, stories that were written down long ago are in the public domain. Stories that were passed down orally and only recently written down are a more complicated issue. Also, recent stories built off of ancient traditions are protected by copyright. For instance, Marvel's Thor comic books are protected. Where things would get sticky is if someone wrote a new story about Thor that had similarities to Marvel's Thor: if it was determined to be based off of Marvel, then it would be a derivative work, but if it the two were determined to have the public domain source as common origin, then it would be an original work.
Acccumulation
  • 651
  • Goddess Nike is an ancient Greek goddess. You cannot trademark thousands of years old IP. – Negdo Feb 22 '23 at 12:06
  • @Negdo: The trademark is in the context of selling shoes, not as a deity. – Peter Cordes Feb 22 '23 at 18:48
  • +1 for the point about Nike, but -1 for the discussion of ancient stories. If you write down any public-domain story with original words, you have copyright in that work. Furthermore, ideas are not subject to copyright. If Marvel were to introduce the idea that Thor suffered from a mold allergy and someone else wrote a story in which Thor suffered from a mold allergy, that would not by itself be copyright infringement. – phoog Feb 22 '23 at 20:05
  • @Negdo you can trademark just about any word. Some trademarks are common nouns such as "dove" or "time," noun phrases such as "post office" or "super bowl," or indeed ancient proper nouns such as Ajax, Mercury, and Mars, or newer names such as Lincoln and John Hancock. But you don't have to take my word for it; see for yourself at https://www.uspto.gov/trademarks/search -- or just try selling something under the name "Nike." If you have any success with it, you'll soon find out whether it is a protected trademark. – phoog Feb 22 '23 at 21:55
  • @phoog I don't see how that contradicts what I said. I said " Stories that were passed down orally and only recently written down are a more complicated issue. Also, recent stories built off of ancient traditions are protected by copyright." Also, I said "if it was determined to be based off of Marvel", not "if it had any similarities to Marvel". – Acccumulation Feb 23 '23 at 13:56
Are deity/god names protected by copyright or trademark?
They are not protected by copyright because names simply are not protected by copyright. See for example the US copyright circular 33 (PDF), which says
Examples of names, titles, or short phrases that do not contain a sufficient amount of creativity to support a claim in copyright include
  • The title or subtitle of a work, such as a book, a song, or a pictorial, graphic, or sculptural work
  • The name of a character
These names may in fact be subject to trademark protection if someone has been using them as a trademark. But trademark protection is widely misunderstood. Trademark protection prevents you from using the name "Nike" to sell athletic gear or to engage in any other line of business where someone is already using the name Nike. It does not prevent you from writing stories about deities named Nike or about Nike-branded sportswear.
phoog
  • 111
