Would it be acceptable to regularly meet with potential sources for interviews that may end up remaining unpublished indefinitely, or could such a habit be impolite? Clearly there is tremendous value in being able to use whatever raw material one has to the fullest extent possible. On the other hand, I can imagine how requiring a kind of full awareness of the end product might diminish journalistic activity, especially for amateurs such as myself, or could be at odds with the starting premise that exploration (a) exists, i.e. is not just a figment of our imaginations, and (b) is worthwhile.
My current perspective is that experienced professional journalists are probably expected to produce a story from each interview and might ask if it would be acceptable not to, while the reverse holds for amateur or inexperienced journalists (i.e. that a publication is not expected, and that although one is probably not unwelcome, it is best to ask permission in advance). Are there other factors that might be worth considering?
Laurel
  • 4,053
  • 39
TLDR
  • 111
  • I'm not an expert, but I've heard of journalists interviewing numerous people over and over, and if they can't get enough for an article, they just end up as notes. There's no guarantee an interview will result in something getting published. You might even use an interview as supporting evidence for the person you actually end up quoting. I've heard of 'journalists' paying people for interviews, signing non-compete/do-not-share contracts, then never intending to publish as a way to silence them. That would be unethical, but I don't have the references, so don't quote me. ;) – DWKraus May 25 '21 at 21:55
I'll try to answer, although I am not sure what your sentence about the starting premise that exploration exists and is worthwhile is referring to exactly.
There are background interviews, and there are interviews done to produce stories for publication. There are also casual talks with sources, social meetings, and other kinds of contacts that may or may not result in something getting published. There are interviews that produce Q&A stories, where most of the interview is published, and there are off-the-record interviews where nothing that gets published can be attributed to the interview subject.
In other words, no, every interview does not have to be for a published story. However, as a subject or source, I would wonder why I was answering questions if there was no intent to produce (eventually) a story. Also, more than one interview (with maybe follow up questions later) is unusual -- unless the subject has time on their hands and likes talking about the topic of the interview.
If I were planning a book, I probably would set up a series of interviews, and would explain that I was researching the topic and was not yet sure how the material would be used. I would follow up with the interviewees when I had a more concrete outline to be sure they were comfortable with the scope of their participation.
It is impolite to waste people's time, of course. But if you are up front and honest about your intentions, you will avoid misunderstanding. You can certainly approach a source and request an interview because you want to learn more about a topic or gain background information that helps you decide if there is a story to be written. Student journalists often have to request interviews and explain that the result is expected to be a class paper, not a widely published article. People are often generous with their time to help students educate themselves.
To show respect to your subjects, be prepared, be on time, don't ask for more time than you need -- 45 minutes to an hour is about as much as you can ask of busy people. If you really need to have a series of interviews with the same people, you have to make it convenient for them and somehow worth their time -- not with compensation, but by helping foster communication in which they are interested.
user8356
  • 1,323
