I need Tor to connect to my adult website "test11.easyxtubes.com". For some reason it will not connect as it is HTTP. It seems all tor traffic HTTPS. My question is how can I force tor to connect to my HTTP website. If I need to alter torcc please provide me an example.
My OS is Kali Linux 2.0
Glorfindel
  • 183
  • 15
user10045
This can have several reasons:
  1. Tor Browser comes with HTTPS Everywhere. This addon has rules for several sites to connect via HTTPS. At https://atlas.eff.org/index.html?tubes you can see all sites which contain tubes. Your site is not among them.
  2. There is a chance that the site itself redirects your request to the HTTPS. You can check it with curl. Just enter curl -I your-site.example.com. Look at the first line and the line with the Location: header. When there is a redirect you see HTTP/1.1 301 or some other 3XX number. The Location: tells you the target of the redirect.
  3. It also might be the case that the site has a HSTS header. So when you visited the site before via HTTPS and the HSTS header is set, your browser will always try to visit the site over HTTPS again. You can also check it via curl.
Jens Kubieziel
  • 8,630
  • 35
  • 116
