I'm trying to create a private Tor network and currently configuring the Directory Server. I run the command
tor --list-fingerprint
But it returns
Clients don't have long-term identity keys. Exiting.
If I correctly understand, I need the fingerprint for this line in torrc config file:
DirServer [nickname] [flags] address:port fingerprint
Where should I get the fingerprint for the Directory Server ?
Thank you
Daniel
  • 171
Instead of doing this all manually, you might want to try out Chutney (https://gitweb.torproject.org/chutney.git/) to set up a private network for you.
To answer your question directly, you need to create a dummy configuration. The following will work:
DirServer test 127.0.0.1:1 0000000000000000000000000000000000000000
OrPort 1
DataDirectory /path/to/directory
Sebastian
  • 2,229
  • 26
