I installed tor on a ubuntu-server with the command
sudo apt-get install tor
and I also installed socks:
sudo cpan LWP::Protocol::socks
After this i wrote a perl script to read websites using the tor network, which works very well (simplified example):
#!/usr/bin/perl
use strict;
use LWP::UserAgent;
my $ua = LWP::UserAgent->new('agent' => 'any user agent string'},
$ua->proxy([qw/ http https /] => 'socks://localhost:9050'); # Tor proxy
$ua->cookie_jar({});
my $response = $ua->get('http://www.example.com/');
print $response->content;
As said before, this works very well, but there are some servers who block some tor exit nodes. Instead of sending the expected content with http-status 200 (ok) they send the status 403 (forbidden). But some minutes later the same server sends 200 (ok) together with the expected content, so I'm pretty sure that the problem are exit nodes who's IP addresses are blacklisted.
I know, that tor itself changes the route (and so the exit node) as far as I know every 10 minutes. But in the case, that a server sends 403 because it has made bad experiences with the concrete exit node that I'm using in this moment, I don't want to wait 10 minutes to get another exit node that hopefully is not blocked.
I want to change my perl script into something like this:
#!/usr/bin/perl
use strict;
use LWP::UserAgent;
my $code = 403;
my $content = '';
while ($code > 399) {
    $code = $response->code();
    if ($code > 399) {
        #  TELL TOR TO USE A NEW EXIT NODE  #
    } else {
        $content = $response->content;
print $content;
Note, that this example is simplified: Not all http-status above 400 are usefull to change the route, and there are also some other reasons, that make it necessary to tell tor to use a new exit node.
My question is:
a) How can a perl script tell tor to change its route?
b) What other possibilities are there to control tor from a perl script?
