I am trying to use Tor with Windows10 (I know, I know...). All seems to go well but I can't connect to any site ("connecting" then back to the welcome page). Same thing with the anti-virus and firewall ( G Data) deactivated. Same thing with another bridge. Same thing using another PC with Vista and another ISP. Here is the log ; thank you for heeeelp.
13/10/2015 17:19:02.800 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
13/10/2015 17:19:02.800 [NOTICE] Opening Socks listener on 127.0.0.1:9150
13/10/2015 17:19:09.800 [NOTICE] Bootstrapped 5%: Connecting to directory server
13/10/2015 17:19:09.800 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server
13/10/2015 17:19:10.300 [WARN] Proxy Client: unable to connect to 169.229.59.75:46328 ("general SOCKS server failure")
13/10/2015 17:19:10.400 [NOTICE] Bootstrapped 15%: Establishing an encrypted directory connection
13/10/2015 17:19:10.400 [NOTICE] Bootstrapped 20%: Asking for networkstatus consensus
13/10/2015 17:19:11.200 [NOTICE] Closing no-longer-configured Socks listener on 127.0.0.1:9150
13/10/2015 17:19:11.200 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
13/10/2015 17:19:11.200 [NOTICE] Closing old Socks listener on 127.0.0.1:9150
13/10/2015 17:19:11.200 [WARN] Problem bootstrapping. Stuck at 20%: Asking for networkstatus consensus. (DONE; DONE; count 1; recommendation warn; host A09D536DD1752D542E1FBB3C9CE4449D51298239 at 83.212.101.3:80)
13/10/2015 17:19:11.200 [WARN] 2 connections have failed:
13/10/2015 17:19:11.200 [WARN]  1 connections died in state handshaking (proxy) with SSL state (No SSL object)
13/10/2015 17:19:11.200 [WARN]  1 connections died in state handshaking (TLS) with SSL state SSLv3 read finished A in HANDSHAKE
13/10/2015 17:19:11.700 [NOTICE] Delaying directory fetches: DisableNetwork is set.
Jens Kubieziel
  • 8,630
  • 35
  • 116
Griffono
  • 31
The log you have pasted indicates you set the configuration option DisableNetwork, which is where your problem originates. Unset the option and it should work.
Sebastian
  • 2,229
  • 26
