I am trying to get an HTTP request through a private Tor network that I have setup using tunneling with socat.
In a private Tor network (10.0.0.216/29) I have relays setup on my servers 218 and 221 through which I am manually creating a circuit (218 -> 221). I have Apache running on 222 and hope to load the default page through a connected client.
I take 217 as a client and after creating the circuit, I use the following command:
curl --socks4a localhost:9050 10.0.0.222
This works successfully. Then I try to create a bidirectional tunnel using socat by the following command
socat TCP-LISTEN:9000 SOCKS4A:127.0.0.1:10.0.0.222:80,socksport=9050 &
And I try to access the same resource using curl -v localhost:9000 but there is no response. The verbose output:
* Rebuilt URL to: localhost:9000/
* Hostname was NOT found in DNS cache
*   Trying 127.0.0.1...
* Connected to localhost (127.0.0.1) port 9000 (#0)
> GET / HTTP/1.1
> User-Agent: curl/7.35.0
> Host: localhost:9000
> Accept: */*
The connection times out after some time. Here is the clause that continuously is repeated in the info.log debug log file.
Oct 07 13:19:52.000 [info] choose_good_exit_server_general(): Found 1 servers that might support 1/1 pending connections.
Oct 07 13:19:52.000 [info] choose_good_exit_server_general(): Chose exit server '$<fingerprint of OR221>~OR221 at 10.0.0.221'
Oct 07 13:19:52.000 [info] compute_weighted_bandwidths(): Empty routerlist passed in to consensus weight node selection for rule weight as guard
Oct 07 13:19:52.000 [info] smartlist_choose_node_by_bandwidth(): Empty routerlist passed in to old node selection for rule weight as guard
Oct 07 13:19:52.000 [info] router_choose_random_node(): We couldn't find any live, guard routers; falling back to list of all routers.
Oct 07 13:19:52.000 [info] compute_weighted_bandwidths(): Empty routerlist passed in to consensus weight node selection for rule weight as middle node
Oct 07 13:19:52.000 [info] smartlist_choose_node_by_bandwidth(): Empty routerlist passed in to old node selection for rule no weighting
Oct 07 13:19:52.000 [warn] No available nodes when trying to choose node. Failing.
Oct 07 13:19:52.000 [warn] Failed to find node for hop 0 of our path. Discarding this circuit.
Oct 07 13:19:52.000 [info] onion_populate_cpath(): Generating cpath hop failed.
Oct 07 13:19:52.000 [info] circuit_get_open_circ_or_launch(): No safe circuit (purpose 5) ready for edge connection; delaying.
Oct 07 13:19:53.000 [notice] Tried for 120 seconds to get a connection to 10.0.0.222:80. Giving up. (waiting for circuit)
Any help is appreciated.
PS: I am trying to use socat as torify and torsocks do not seem to work for connections having a local DNS address resolution.
