Last login: Mon Oct  5 23:12:01 on ttys000
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:02.300 [NOTICE] Opening Socks listener on 127.0.0.1:9150
15-10-05 23:17:02.300 [NOTICE] Renaming old configuration file to "/Applications/TorBrowser.app/TorBrowser/Data/Tor/torrc.orig.1"
15-10-05 23:17:02.600 [NOTICE] Bootstrapped 5%: Connecting to directory server
15-10-05 23:17:02.800 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server
15-10-05 23:17:03.400 [NOTICE] Bootstrapped 15%: Establishing an encrypted directory connection
15-10-05 23:17:03.600 [NOTICE] Bootstrapped 20%: Asking for networkstatus consensus
15-10-05 23:17:03.700 [NOTICE] Bootstrapped 25%: Loading networkstatus consensus
15-10-05 23:17:06.200 [WARN] Received directory with skewed time (server '171.25.193.9:80'): It seems that our clock is behind by 2 hours, 54 minutes, or that theirs is ahead. Tor requires an accurate clock to work: please check your time, timezone, and date settings.
15-10-05 23:17:06.200 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
15-10-05 23:17:06.300 [NOTICE] Bootstrap-bash: 15-10-05: command not found
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:02.300 [NOTICE] Renaming old configuration file to "/Applications/TorBrowser.app/TorBrowser/Data/Tor/torrc.orig.1"
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:02.600 [NOTICE] Bootstrapped 5%: Connecting to directory server
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:02.800 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:03.400 [NOTICE] Bootstrapped 15%: Establishing an encrypted directory connection
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:03.600 [NOTICE] Bootstrapped 20%: Asking for networkstatus consensus
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:03.700 [NOTICE] Bootstrapped 25%: Loading networkstatus consensus
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:06.200 [WARN] Received directory with skewed time (server '171.25.193.9:80'): It seems that our clock is behind by 2 hours, 54 minutes, or that theirs is ahead. Tor requires an accurate clock to work: please check your time, timezone, and date settings.
-bash: syntax error near unexpected token ('
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:06.200 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:06.300 [NOTICE] Bootstrapped 40%: Loading authority key certs
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:06.500 [WARN] Received directory with skewed time (server '199.254.238.52:443'): It seems that our clock is behind by 2 hours, 54 minutes, or that theirs is ahead. Tor requires an accurate clock to work: please check your time, timezone, and date settings.
-bash: syntax error near unexpected token('
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:06.500 [WARN] Our clock is 2 hours, 42 minutes behind the time published in the consensus network status document (2015-10-06 06:00:00 UTC).  Tor needs an accurate clock to work correctly. Please check your time and date settings!
-bash: syntax error near unexpected token `('
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:06.500 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no recent usable consensus.
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:23.500 [NOTICE] Closing no-longer-configured Socks listener on 127.0.0.1:9150
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:23.500 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:23.500 [NOTICE] Closing old Socks listener on 127.0.0.1:9150
cesar-montanos-MacBook:~ cesarmontano$ 15-10-05 23:17:23.900 [NOTICE] Delaying directory fetches: DisableNetwork is set.
here is a copy of my log.
            Asked
            Active
            Viewed 60 times
        tonny
- 21
- 2
