I understand how to configure the torrc config file in order to access internet through Tor bridges.
But the scenario is such even though my ISP allows Tor traffic I still do not want my ISP to easily know I am using Tor. i.e. through IPs I’m connecting to that belong to directory authorities, Tor Relays and other Tor services.
I do not mind my ISP suspecting of the ports used by me as long as traffic is not decryptable by them.
I want to force Tor running on my computer to send data i use through Tor browser via the Tor bridge and the bridge only.
How can I do this?
Denis
  • 330
  • 19
One way to do what you are looking for is to setup bridges and then block access to Directory authorities and/or other IP addresses in some manner in your system. This will force directory authorities and/or other IP addresses to connect via bridges. An example of how to block access to directory authorities and/or other IP addresses may be found in this question and answer: Host List Blocking
Roya
  • 3,240
  • 19
  • 40
When we add a Tor Bridge all Tor connections and data are sent through that bridge and that bridge only. I found this answer by emailing tor.
Denis
  • 330
  • 19
